9 Pages «<45678>»
going to have a go Options
jinks8
#101 Posted : 14 October 2010 00:54:31
Sorry it has bin so long but had a lot of things to do but an starting to get in to building again hear are sun pick’s of issues 11& 12. Got voated best boat for this year by club members for my Bismarck chufet to bists A bit out off focuses but had to use my phone
budgie
#102 Posted : 14 October 2010 09:55:16
Drool BigGrin congratulations on ure Bismark
BigGrin says a lot for ure skills & a plus for Hachette pity no longer available in UK (Bismark)
jinks8
#103 Posted : 20 October 2010 14:22:19
Thanks budgie hope you can still get parts direct from Hachette as need a few bits to do Bismarck’s sister.
budgie
#104 Posted : 20 October 2010 20:01:24
Confused will that be the Tirpitz
is that another Hachette job or a scratch build
jinks8
#105 Posted : 21 October 2010 01:42:53
will be derivative of Hachette Bismarck got 2 second still in a box as yet but all their just need more guns and stuff like that Did not intend to get 2 but had mishap with sum of the mag’s grand sun spilt coffee on around 60 issues and did not tell me then a offer on EBay for 65 mag’s got them,then what the hell over half way their ordered rest from paper shop.
jinks8
#106 Posted : 21 October 2010 18:41:51
hear are photos of issues 13/14 53 should have around bit as in 54
jinks8
#107 Posted : 27 October 2010 02:43:47
Hi gentle builders of the Yamato more pick’s of my build .covered the barrels so get on to pick’s of the rest of the guns so far they are stuck on to painting board with dubbel sided sticky backed plastic Have started to put the rails on to the flight deck for this I got sum straighter rod model shop for better fit. I t was then treated with Car’s metal conditioner and Carr’s metal black cut to length and glued in with cryo All so dune the underside of flight deck not to specks as it has to be removable but wanted to give sum definition and a hint of the rails and brackets
budgie
#108 Posted : 27 October 2010 12:03:50
BigGrin when building plastic model ships when a kid i would always build the guns first (the best bit i thought)
BigGrin looks like i have one or two to do to satisfy my craving
Thanks for pics nice to see whats to come
jinks8
#109 Posted : 27 October 2010 19:51:56
Got all the rails and turn tables on the flight deck and the ladders and platforms on the bridge tower £%$&**just cut my thumb blood all over the place ho well first time on the Yamato glad got deck sealed all so got the stack put together Stack and guns not fixed yet
budgie
#110 Posted : 27 October 2010 20:26:32
Drool superstructure coming together lookin' goodDrool Drool
I see ure before & after pics dull & shiny & the tin shiny too getting a bit carried away with the emery cloth??? but lettering on tin not scratched??
so i was wondering if u are using some other method for cleaning up the metal parts
jinks8
#111 Posted : 27 October 2010 23:23:03
Hi budgie get most of with 400 wet and dry then finish of with the finest you can get used wet it is messy but gives a grate finish
jinks8
#112 Posted : 27 October 2010 23:37:26
Can not find where to congratulate Tomick on his build it look to be going good so will do it hear
#113 Posted : 28 October 2010 11:16:01
Thanks jinks8, your efforts look great too Cool
Yes all is going well and coming together nicely, the number of guns makes you realise just how powerful the Yamato was, it should turn out an impressive model even in its standard form.
jinks8
#114 Posted : 28 October 2010 22:26:42
Started to drill scuppers and put on what they are calling the load line. This not a load line but a Degaussing cable and has sum thing to do with magnetic mines? I have not cut the plans sent but stuck low tack tape on to them and traced the scuppers and Degaussing cable on to it then stuck it on to hull hope the pics will make it clear. I have used Tamiay 18mm it sticks firmly to the paper but can still be peeled off. One word of warning use short lengths to long and it will be hard to control The filler on the bow photo 5 is to fill scuppers as they did no look wright in fact a complet mess forgot to say thanks Tomick
#115 Posted : 29 October 2010 09:26:37
Jinks, if you look at photos of the reals ship, what they call load line cables are actually housed into a rectangular box section which runs around the ship, other than at tight corners where the cable is visible such as at the stern.
So it might be an idea to ditch the wire and use plasticard strips, and form mounting straps over the section, have a lok at the photos below which are of the 1/10 Kure museum Yamato.
jinks8
#116 Posted : 30 October 2010 21:58:53
Thanks Tomick for the heads up on that one spent today geting a round cable to look box shape think it went well
#117 Posted : 30 October 2010 22:31:43
Looks good, I was toying with the idea of brass wire staples to resemble the securing brackets for the section which would be a labour of love Crying
jinks8
#118 Posted : 31 October 2010 00:18:01
That would be one heck of a job think I will give that one a miss you can go to far especially on a model of this size good luck if you do had my little eccentricity on the windows of the command bridge and the deck.
budgie
#119 Posted : 31 October 2010 22:11:45
BigGrin Hi Jinx saw ure pics thought u used lenths of square brass plated rods
read on that u used round wire which u made square
Drool well done Drool am green with envy on your patience & skills
"hats off to u sir"
i might (will)cheat when i eventually get to that stage as noticed on visits to modelling shops that u can purchase cube (square) strips of styrene
thanks for putting up pics appreciated
jinks8
#120 Posted : 01 November 2010 01:14:22
Y thanks Budgie would have left them round but for Tomick sending me photos and i thank him for it so could not leve then round. His build is coming grate,I an going to start the outher side tomorow morr, sorry today have din looking at the photos Tomick sent and on the bow it looks as if the coil runsin to a gril lick thing will have to chech it out.Look at photo on last page
9 Pages «<45678>»
This page was generated in 0.190 seconds.
