9 Pages 123>»
Micks aka Mogwai C57 build diary Options
#1 Posted : 20 May 2016 14:17:55
Hi all ill be the first to put build diary here.I have just subscribed to this on the 12 month subscription. I will start build diary here when me first pack arrives. Looking forward to this one as love steam trains. Cheers and happy moddeling mick. (Big grin)
#2 Posted : 20 May 2016 15:12:33
Look forward to seeing you make a start Mick.
I'm going to go for this one myself. I have to admit I'm not so much into trains but I do think this looks fascinating in all the pictures and am always looking for something different. This fit the bill this time [biggirn]
#3 Posted : 20 May 2016 15:35:18
Hi dave.look forward to your build diary to.did you go 12 or 24 month option?.looks a great kit.ill probably weather mine up a bit, but I'll see what looks like pre painted first. Till make final decision on that.cheers mick. (Cool)
#4 Posted : 20 May 2016 18:56:35
Looking forward to the start of your diaries, seems to be a cracking good kit.
Good luck.
#5 Posted : 20 May 2016 19:05:55
Hi Mick
I will look forward to your build, she is a great kit.
#6 Posted : 20 May 2016 22:50:34
You can add me to you list of followers, always great to see builds start up and to watch their progress..... She looks like she will turn out to be a fab kit to build....
#7 Posted : 21 May 2016 10:28:40
Good luck with your build Mick, look forward to seeing how you get on.
steviecav
#8 Posted : 23 May 2016 11:42:48
Rank: Amateur Level 1
I look forward to watching your build. Good luck!
#9 Posted : 27 May 2016 12:07:05
Hi.I wondered why had heard nothing about this, or why they not take any money.Anyway phoned up today, and found out they were having stock issues on this one.And have only just got stock in today from main warehouse.so be slight delay getting first parts.I was told to call back Tuesday, if money had still not been taken.I'm sure we get there and look forward to making a start soon.Cheers mick.
#10 Posted : 09 June 2016 18:44:13
Hi finally made a start on this.by doing the first 3 stages.all parts are superb quality, and have had no fit issues. Like Andy on the official build I'm using 5 min epoxy, to glue it together.to stop the fogging you get with superglue. So it name plate on boiler door.then fit that.and add the drive rods to the first set of drive wheels. Cheers and happy moddeling mick.
#11 Posted : 09 June 2016 19:20:59
Looking good and nicely done.
#12 Posted : 09 June 2016 19:52:19
Nice one Mick.
Good to see you under way with this one.
#13 Posted : 12 June 2016 15:27:29
Hi decided to update this issue by issue.as packs from now on will have quite a bit to do
ISSUE 4
has us build up the spark arrester. Then glue it inside boiler.and fix two plastic pins in boiler, one each side.then attach handle to right side only.all fitted well, and glued with 5 min epoxy. That's it for pack 1.but get 8 issues a pack next time.cheers mick.
#14 Posted : 12 June 2016 15:37:29
Hi sorry messing about with arrows and txt, forgot to resize pics.
#15 Posted : 19 July 2016 15:13:52
PACK 2/12
we start the second pack stage 5, with fitting the front deck.glued an screwed on.fits well easy job.
Stage 6
The feed water system. This involves gluing the ends in the tank, putting the holding plate on then screw an glue to front deck. You will need a thin barreled screwdriver for the bottom 2 screws here, as they are very close to the ends of the tank. And access is tight.all fitted together well.no problems.enjoying this very much. Cheers mick.
#16 Posted : 19 July 2016 16:32:38
Looking good Mick.
#17 Posted : 19 July 2016 17:12:39
STAGE 7
release lever
This just involves putting 4 brackets on the lever, and gluing to front bumper.
STAGE 8
this involves putting on second plate of front deck, put 2 levers through this.had to lightly file slots to get levers through.and attach front bumper, to front deck via 2 screws behind levers.then add the inspection plates, with steps glued to them. Insert the side plates(the white bits) and tighten 5 screws each side to hold these in place.4 more stages to do for this pack.all fitting very well together.cheers mick.
#18 Posted : 19 July 2016 19:06:21
Nicely done
#19 Posted : 19 July 2016 20:42:58
Nice one Mick, I've nearly finished that pack myself so will upload pictures later in the week. Hope you're enjoying it as much as I am.
#20 Posted : 19 July 2016 22:44:01
Looking good Mick, very clean and tidy work....
9 Pages 123>»
This page was generated in 0.314 seconds.
