10 Pages «<56789>»
Gokstad Viking Ship by Jack.Aubrey, Dusek Shipkits, 1:35 Scale. Options
#121 Posted : 12 June 2016 10:00:14
She really is looking fabulous, excellent craftsmanship....
jack.aubrey
#122 Posted : 12 June 2016 13:38:33
Sunday, June 12, 2016
After a few days of training on the usage of the mini lathe PROXXON DB250, when finally I felt ready enough, I started to build a couple of oars which equipped the Viking ship.
The starting raw material is a 3mm beech dowel. The kit provides rods of the same diameter of lime wood. I preferred to use the beechwood because during the tests the limewood sometimes broke. This problem never occurred me with a harder wood such as beech.
To lathe the handle of the oar (diameter 1.5 mm) and the main part of the oar (diameter 2mm) it takes a lot of patience and care.
Once finished with the lathe, to shape the blade I used the belt sander PROXXON BS/E, much more effective than other manual tools such as files and/or sanding blocks.
Anyway, to build an oar with this procedure I took about 30 minutes, most of them working at the lathe . . . so far so good but the problem is that I have to build 30 of them !!!!
Here below a picture of what the instructions say and two photos of how I interpreted, in my own way, the shape of the oar. Once completed the oar will then be dyed with mordant, even if the idea to paint with dark red or yellow the oar blades is strong . .
Cheers, Jack.
jack.aubrey
#123 Posted : 22 June 2016 15:28:07
Tuesday, June 21th, 2016
About 10 days ago I posted my last message where I showed the "first oar" for this ship. The oar was made using a minilathe for wood.
Here what happened during these past 10 days:
- the first two days I was able to build only three new oars as my limited experience with the lathe led me to break many pieces while using the tool in an unsatisfactory way;
- then, slowly and mistake after mistake, I learned the right method and the correct sequence of execution and from that moment I had no more broken pieces;
- however, given the repetitive and boring nature of the task and its relative slowness, I set myself the goal to run 5 oars per session, not more.
Now it remains to prepare the last five oars and this task will be finally over . .
In the above picture you will notice that, apart from the three oars at the top, the tip (blade?) is not yet shaped. This will be the next step as soon as the last five will be ready.
The temptation to paint the tips with the same yellow color used for the shields is strong. Perhaps, for the rest of the oar, the obvious color should be the same tar brown of the hull but I would prefer a lighter nuance, to add more color effects at the whole model.
Cheers, Jack.
Gibbo
#124 Posted : 22 June 2016 16:20:38
looks very time consuming Jack but well worth the effort, looking forward to your next update.
Paul
jack.aubrey
#125 Posted : 26 June 2016 17:05:34
How I made the ship oars with my wood mini lathe
Some days ago I was asked to prepare a tutorial about the method I used to prepare the 30+ oars of the Gokstad Viking ship. During the session I build the last five oars still needed I took, after each important step, an image of the work done. This in order to make (I hope) easy to understand how I worked and the correct usage of the lathe for this task.
Image 01 shows the raw material I used to build the oar: a rod of beechwood with diameter +/- 4mm. The total length of each rod is in my case 18mm circa and each oar has four segments of 13mm (handle, +/- 1.5-1.7mm diameter), 30mm (not to work on), 82mm (to be reduced at 2.5mm diameter), and the remaining (blade, not to work on for the moment). Each segment is marked on the rod with a pencil before starting to work on the lathe.
01 Tornio/10_zpslvyqlcxx.jpg
The tools used for this task: mini sanding blocks of different grade, chisels of different shapes: everyone will find the better suitable for him or for the task.
02 Tornio/15_zpswkv2wz7r.jpg
Insert the rod into the lathe clamp after having previously drilled a small hole on the tip close to the handle side. Clamp the rod 20mm after the end of the 13+30mm markers. Block the stable tool support as close as possible to the rod.
03 Tornio/20_zps0cdgbgg3.jpg
Position the tailstock with the quill travel, center the small hole on the tip and block it.
04 Tornio/25_zpsfgbeqfhn.jpg
Power on the lathe and reduce the diameter of the rod as shown below with your preferred tool. Personally I use first the chisel and later the sanding blocks to refine.
05 Tornio/30_zpsw25jxosg.jpg
Poweroff the lathe and extract another 2mm rod from the lathe and clamp it again . .
06 Tornio/35_zpsrwk9niuu.jpg
Power on the lathe and restart the diameter reduction for the next 20mm segment . .
07 Tornio/40_zpsoypuqveo.jpg
Repeat the steps until you reach the end of the 82mm. segment. The reason I proceeded working only of 20mm segments is related to the flexibility of the reduced diameter area (about 2.5mm). If you work on longer segments you risk to break the rod and the complete work done is then lost.
08 Tornio/45_zpswnjneuau.jpg
09 Tornio/50_zpsj5xn71tv.jpg
At this point insert the rod into the lathe, close to the oar handle. Clamp the rod and position the tailstock again.
10 Tornio/55_zpsmgdzlrdj.jpg
Lathe the oar handle. The handle should have a diameter of 1.5-1.7mm.
11 Tornio/60_zpsuryuj1gr.jpg
Cut the excess tip, now no more useful and refine with sanding block.
12 Tornio/65_zpsfiqoqsl2.jpg
Extract the oar from the lathe; now this task is over and it remains only to shape the blade . .
13 Tornio/70_zpsgirr6tfm.jpg
All the oars are finished . . although the blade shaped tips are still to be done . . will be a matter for next messages.
14 Tornio/20160621_163501_zpsi2myuze1.jpg
That's all for now . . to the next progress step (blade tips).
Regards, Jack.Aubrey.
#126 Posted : 26 June 2016 18:05:47
Hi Jack,
That`s a great "How To" within a build diary.
WTG
#127 Posted : 26 June 2016 20:37:04
Stunning work as always
jack.aubrey
#128 Posted : 04 July 2016 17:58:49
Saturday, July 2nd, 2016
Second phase of the oars construction: the blades have already been shaped by a specific processing, using, for roughing, the belt sander BS/E from Proxxon fixed on a vise in a inverted position and, for finishing, a normal sandpaper. Then, when the 30+ blades were over, I went further to stain the wood as its natural color, as you can see in the picture 02, is too light.
Finally, I painted a) the blades (work still in progress, four coats of paint are needed !!) with the same acrylic yellow used to paint the shields and b) the handle of the oar, painted with the same dark red used for shields too.
Their appearance seem now to much new !! Just left the shipyard . . Thinking to another ageing process.
To next time, Jack.
daffy09
#129 Posted : 04 July 2016 20:24:13
Lovely work on the oars Jack. I agree some sort of aging/weathering would look good. back to the vinegar and wire wool again! lol
Happy building
David
Gibbo
#130 Posted : 04 July 2016 22:09:16
That was a lot of work Jack and well worth the effort, they look fantastic.
Paul
jack.aubrey
#131 Posted : 12 July 2016 19:56:11
Tuesday, July 12, 2016
Today I drilled the hull to prepare the oars housings: holes of 3mm diameter to be carefully drilled. In fact I started with a drill bit of 1mm, then 2mm and, finally, 3mm. Subsequently, in order to let the oar blade to pass in the hole, I run a slight lateral incision into the hole so that it lets only pass the blade and not the rest. Obviously the lat incision is made in the right direction for the force applied during the rowing. The finishing is made with a round nail file to remove burrs and a coat of stain to darken the wood thickness that, after the drilling, is clear.
Display test for the finished model, with oars inserted in their slots. . what about ?
There is a drawback: the greater width of the display case, but on a model of this size this is not a real problem. I'm also thinking that probably it's not the case of aging alchemies for the oars, because the coordinated view with the shields does not seem out of place at all. .
Regards, Jack.
PS: Thanks to all of you for your positive comments . .
Nytetrain
#132 Posted : 12 July 2016 23:34:40
She is looking fantastic Jack. Keep up the good work. I admire your attention to detail and your patience to do top notch work. Beautiful model. How close to finished is she?
Ron
Best Regards,
Ron
On the bench: DeAgostini '67 Ford Shelby Mustang, Hachette Space Battleship Yamato 2202, Agora Models T-800 Terminator
Finished builds: DeAgostini Toyota 2000GT
In the Stash: Losing count...
jack.aubrey
#133 Posted : 13 July 2016 09:09:11
Ron
Hi Ron,
I don't think there are many things left to do . . Supposing to work on it with regularity I think possible to close the project in a couple of months. But I'm generally too slow and now the summer holidays time is also coming . .
Considering that all the single pieces are 99% ready, these are the tasks left to do:
- install the rudder
- install and rig the mast
- build the sail and place it on the yard, rig the whole
- (not included into the kit) the seats for the oarmen
- the display case (not included in the kit) with a glass or polycarbonate cover
May be I forgot something but these should be the main task to achieve.
Rgds, Jack.
jack.aubrey
#134 Posted : 13 July 2016 09:16:14
A few more photos to show the visual effect of the oars exposed outboard. This time I tried to put the model into a lower position, using another "building slip", so that the tips of the oars now lie on the hypothetical ground of the case. In this way you can better position the oars, with an aesthetic effect that seems much better to me.
But with the positioning of the oars in this way the logic would dictate that the yard/sail should not be mounted. . The mast can stay installed erected but the yard should be exposed, only with the inferred sail rolled up, on special supports amidships. They are three in total but the pictures here show only the middle one, placed on the deck.
Any Comments ? Jack.
#135 Posted : 13 July 2016 15:30:15
More beautiful work on display from you Jack.
I'm really looking forward to see her finished with the sail and rigging all in place.
Will you be making a display case yourself?
jack.aubrey
#136 Posted : 22 July 2016 17:01:40
Thursday, July 21, 2016
Started the tasks to build the display case basement, to be completed, at the end, with a plexiglass cover . .
The basement seen from its natural position: stained with a chestwood colored solution, the groove to hold in the plexiglass cover ready, with the outer frame that will be painted with the same dark red colour I used for the shields.
The lower part of the basement, with four wooden "feet" already added, to be painted dark red too.
A detail of the four lower feet (is it the right term ?): I used simple knobs for drawers, easily available in DIY stores. I used a two-component epoxy glue, enforced with an internal metal pin.
jack.aubrey
#137 Posted : 23 July 2016 09:56:39
A complex piece made with hard wood from which I got the two brackets to support the hull. They will be placed over the display case basement.
With a cut made in the right place, done with the yable saw, I got the two pieces shown here below which will hold the keel on the basement shown in the previous message.
Now I have to drill them to accommodate the keel holding screw.
Then I'll paint them dark red (same color of the shields).
To be finally fixed on the basement in the correct position.
Cheers, Jack.
My personal assistant to check the proper progresses of my work in its strategic role as project supervisor . .
#138 Posted : 23 July 2016 16:30:25
Jack
That build has come on a treat since i last looked in.
Very skilled workmon the oars managing to get them all the same shape - that really is good.
Looks like your cat has been "working very hard" and is in need of a rest.
#139 Posted : 23 July 2016 19:51:15
jack.aubrey
03 [url=http://s46.photobucket.com/user/tom-pullings/media/Viking%20Gokstad%20Ship/20160712_125223_zpsunmdxcg9.jpg.html wrote:
[/url]
Fantastic looking model!
Unusual that there are no thwarts for the oarsmen to sit on.
#140 Posted : 23 July 2016 23:41:44
Superb and a joy to see.... very well done...
10 Pages «<56789>»
This page was generated in 0.261 seconds.
