RB-7 Piston fit problem Options
AlDove
#1 Posted : 16 June 2016 19:58:14
Rank: Newbie
My cylinder and piston on my RB-7 seem to fit too tight at TDC but I am new to Nitro Engines so I'm not sure.
With the crank, sleeve, piston and connecting rod all installed I cannot turn the engine through TDC with out the piston lifting the sleeve out of the block. And if I install the cylinder head it stops around 1/16" BTDC.
Is this normal? Does it need to be that tight for good compression? Will the pull starter overcome this stiff spot?
Anybody? I am baffled and don't want to hone the sleeve out any if this is how it should be.
#2 Posted : 16 June 2016 20:47:27
Welcome to ModelSapce.
See this topic
http://forum.model-space...spx?g=posts&t=12278
#3 Posted : 17 June 2016 01:02:45
hi Aldove,
welcome to the forum.I am forum support for USa so let me know if I can help in any way
This page was generated in 0.402 seconds.
