gregs build Options
greg francis
#1 Posted : 17 June 2016 02:50:39
Rank: Beginner Level 1
Have not posted fore some time. Build is going fine have made a number of mistakes along the way most of these have been able to correct and see others have made the same mistakes.The only one I am not too happy about is the lining of inside of the bulwark on either side of third deck gun ports, some of mine are 1 to 2 mm out of line with the handrail posts. Should have left this work until putting in the hand rails. Have not attempted to remove those that are out of line as yet, they were put in with P V A glue so should be removed with water.
Have added some picks.
greg francis attached the following image(s):
#2 Posted : 17 June 2016 17:01:08
Looking good Greg, keep up the good work,,,
#3 Posted : 17 June 2016 22:44:20
Great work Greg. Doing a fab job.
Chris
#4 Posted : 18 June 2016 07:21:07
Very nicely done Greg
#5 Posted : 19 July 2016 13:59:11
Hi Greg.
Looking very nice. Look forward to seeing more.
Ian.
This page was generated in 0.454 seconds.
