idbox x and y not working Options
f1marshal
#1 Posted : 21 June 2016 12:53:50
Hi all
I have proberly done something wrong here but x and y axis is not working z works fine i was wondering if the head is too tight but really need advice before i try anything.
Everything seems to be ok though other than that and all software has been installed,i have followed instuctions carefully but still stuck.
Thanks in advance
Paul
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
michu
#2 Posted : 21 June 2016 13:11:24
Is it indeed stuck (is there any indication that the motors do try to move the head) or rather it seems they are not receiving the signal at all?
Happy building :-)
f1marshal
#3 Posted : 21 June 2016 13:17:25
there is no movement at all just one motor shuddering a little a bit of noise i think they are receiving the signal
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
michu
#4 Posted : 21 June 2016 13:37:57
I will get back to you in the evening when I have a look at mine and try to understand what might be causing it. I guess you have already checked the obvious stuff: whether you can move the head by hand, are the slider blocks not blocked by anything, etc?
Also make sure the screws securing the pulleys on the motor shaft are screwed in securely.
Happy building :-)
michu
#5 Posted : 21 June 2016 19:11:29
Paul,
I think it might be a dodgy motor. You could try removing it and testing by connecting to some other lead (best would be Z axis lead as you know this works). If it still does the same, then you'll have to contact customer services and order a replacement.
Please let me know how it goes.
Cheers,
Michu
Happy building :-)
f1marshal
#6 Posted : 22 June 2016 06:27:09
Thanks I will try that later just got in from work need some sleep 1st
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
f1marshal
#7 Posted : 24 June 2016 15:32:20
Update
I removed the head rods and reconnected the printer and everything works properly which it was what i was thinking that the rods was too tight, so now i need to get them lined up better as i think it was my error on lining it all up correctly. back to the drawing board it is then as they say.
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
#8 Posted : 24 June 2016 20:28:13
Great stuff , I found lining up the rods with the belts by looking directly down on each one a help with lining up and to see where they are out
This page was generated in 0.268 seconds.
