9 Pages «<56789>
going to have a go Options
#121 Posted : 01 November 2010 10:30:00
More photos of the Kure museum model
jinks8
#122 Posted : 03 November 2010 04:29:16
Nice one Tomick, sum good photos of a 1/35 on this site http://www.geocities.jp/yamato_model_guide/ enuf of that started to do the exhaust pipes
jinks8
#123 Posted : 03 November 2010 04:30:16
jinks8
#124 Posted : 03 November 2010 17:43:23
hi peps eney one out thire going to Warwickshier Exhibition on the 14th will be thire with BMBS would be mice to see sum one and have a chat and compair noats going for the day will be in caff around 12/30
jinks8
#125 Posted : 06 November 2010 02:38:05
Had a rest from sanding filing and started to do sum of the lighting so t was drilling hols and soldering wire LEDs and capacitors The switching gear will be I hope got next Sunday from Hunter’s so it can be turned on and of by remote so as yet on photos of it yet the LEDs are from http://stores.ebay.co.uk/Goodwill-Leds-Sales they cum with the correct capacitors
#126 Posted : 06 November 2010 10:36:49
Its going to look awesome!
jinks8
#127 Posted : 07 November 2010 12:45:01
Thank you Tomick I think you can not beat a boat on the water late evening all lights on last night had bonfire at club and a nice night a lot of boats with lights on was very impressive
jinks8
#128 Posted : 20 November 2010 03:38:59
Time for photos of 15,16
jinks8
#129 Posted : 20 November 2010 04:10:53
Hi gentlemen well could not put it of any had to get the spray gun out and start putting sum detail on the con tower The rear control bridge well the start of it and the props from prop shop the paint is 164 Humbrol dark gray it looks liter than it is
jinks8
#130 Posted : 24 November 2010 01:40:59
Good morning gentle men a few more photos of the super structure have bin trying to get up to the pond at brid but whether has not permitted it so had it in bath and it moved not far but it hit the bath forward and aft rain or no rain on Thursday I an going to put it on the water so should have vid by Friday
#131 Posted : 24 November 2010 09:24:47
Coming along very nicely, good luck with the pond test though it looks like snow is heading your way!
Mac
#132 Posted : 24 November 2010 12:51:47
Shes looking great jinks BigGrin She looks so complicated to build rather you than me.
Pam's shipyard is closed for now no more room!
jinks8
#133 Posted : 27 November 2010 03:42:42
sea trials not good the motors move it but far to slow had to do sum modifications motors now she still has 4 but the 2 outside ones are 280tis from Grupner so if sum of you out there are going my way i an sorry but I did say it was an experiment The reason there is no vid was the whether not there long enough to get sum. Now for the modifications as I stated the 2 outer motors are now 280tis to get them in I had to cut sum of the supports on the port and starboard you can see this in the photos because this may weaken the hull put extra supports in to the side Putting the new motors in the problem was to connect them to the shafts this was done with sum tubing made for the job you can get it and the motors from http://www.alwayshobbies.com [/url] Putting the new motors in the problem was to connect them to the shafts this was done with sum tubing made for the job you can get it and the motors from http://www.alwayshobbies.com The weather was bad snow and windy not a good combo for filming but now the mod’s are dun will try again. Once more sorry to if you have dun it with the small motors the conversion is not hard to do as the 280tis will fit with out having to move the shafts but it must be the 2 outside motors
budgie
#134 Posted : 27 November 2010 06:32:11
BigGrin Hi Jinx thanks for photos coming along very nicely
Cool put motors on hold until i can get rough idea of weight of model
local model shop man can do a calculation for motor & gear ratio (like trying to start driving off in a car in 5th gear if wrong ones used)based on weight/size etc of model
jinks8
#135 Posted : 28 November 2010 03:03:06
You will have to forgive this as first time used vid on phone and got it upside down but if you can stand on your head it is ok copied this of laptop screen Promise to get it better next time will get grand daughter to come and do the vid bit as it is hard hoalding phone and getting a ship on twin stick to go
jinks8
#136 Posted : 01 December 2010 00:44:50
If you can not get hold of a good primer C+L Fine Scale do onehttp:///www.finescale.org.uk this is an etching primer for brass and other metals they are mainly for train people but do a lot good stuff.PS, I get most of my sodering bit and bobs from them
jinks8
#137 Posted : 13 December 2010 01:42:01
Build packs 17/18 has arrived and I think we have a problem 2 packets with the same parts IE 2 Bow Fairlead 4 Machine-gun firing Control Mechanism and 4 bases and 14 launch cranes not that they will not cum in handy as 1or 2 will get lost in sailing her the next is not 070 but 069 o71 must be the plan
jinks8
#138 Posted : 15 December 2010 02:06:53
Hello back again with a bit more of my build first a lot of the first time builders will be looking at the cable drums and scratching of the head so this is my way ( Other ways are available ) first to clean the flat inside get a peace of wet and dry around 4” by 4” and stick it to a flat board This will give you a good flat surface you can smooth and clean the inside of the drum ends lay the end flat side down and with your finger slid it back and forwards 3 or 4 times on more as you could round of the ends. The drums a good set of tweezers and the file supplied in issue 1 my tweezers are a locking type pick up the drum and hold firm on a flat surface and gently flatten the ends with file Now for the putting them together, for this you need to make a gig 2 scrap bits of wood as long as they can be put together to form a right angle on dubbed sided sticky backed plastic Stand one end in to the gig stick the drum free hand to a side plate with S/Glue when dry fix to side in gig this should give you a cable drum that will sit flat on the deck. Still fiddly but better than trying to do them free but get a good set of tweezes and the job will be a lot essayer a few shots of build so far the guns on deck ar not fixt yet riging probely teching my grand mum to suck eggs but when doing the rigging do it aganst aligth back ground the tweezers cum in handy again for thisas well not uesed the coard sent but ten pound fishing line black
jinks8
#139 Posted : 18 December 2010 02:20:34
Hello again on a model that is to be RC one of the things you have to think a bout is the ON OFF switch it has to be placed in an unobtrusive place as pos hence I have put mine under the middle gun gun as mine are not going to be motorized all I have to do is swing the turret to left or right to get at the switch move it back and it is hidden Next the anchor chains have used the sane as on my bissy it is a good double linked chine and used the one sent with the kit as the stay chins these are fastened to the anchor chine with fine fishing line and to the deck with a fine pin Fixing the main tower to the deck mine is dun with 3 screws 2 can be seen in the photo the 3rd is underneath the tower will post photo later of the 3rd
#140 Posted : 18 December 2010 10:31:16
Nice idea's for R/C access and she's looking good!
9 Pages «<56789>
This page was generated in 0.174 seconds.
