5 Pages <12345>
De-Sink the Bismarck! (28/140) Options
#41 Posted : 04 March 2016 16:50:56
greyhawk wrote:
birdaj2 wrote:
Hope the deck fitting on victory goes well BigGrin
I've put it off long enough in any case. Had my share of problems with it and burned out, but I'll need to tackle it now or I will just keep starting new projects instead.
I know exactly how that feels Blushing the number of part built kits i have hanging around is not the right way if doing things BigGrin
#42 Posted : 04 March 2016 17:42:01
greyhawk wrote:
With phase 10 the skeleton of the hull is complete. I'm taking a bit of a break here for now and will fit the Victory with its decks because it keeps staring at me accusingly.
Oh sure leave us dangling!!! Dont leave this one for too long-it is such a great build so far.
greyhawk
#43 Posted : 04 March 2016 18:53:38
It's only going to be issue 17 to 20 for the Vicky, so I have a clean cut, then the Bismarck will get her under clothes.
greyhawk
#44 Posted : 14 May 2016 21:28:59
#45 Posted : 14 May 2016 22:28:18
I remember this stage. 😀 Your doing a great job grey. Taking shape now.
Chris 👍
#46 Posted : 14 May 2016 23:33:44
Ahh, progress on the Bis is always great to see, progressing very nicely....
greyhawk
#47 Posted : 16 May 2016 22:49:23
Had to tear off half the planks and reinstall as the instructions neglect mentioning tapering and chamfering the planks and my guess "Well, maybe I don't need to then" turned out to be a wrong guess.
Anyway, issue 12 is done featuring more planking as well as installation of supports in the stern and the deck structure
#48 Posted : 17 May 2016 01:20:56
looking good there.I am sure your Occre train kit wont give you any problems like this one (snicker)
greyhawk
#49 Posted : 17 May 2016 09:26:00
Yeah, Occre train kit. They want me cut and bend pipes from 1,5mm diameter brass wire now. Should have posted a warning: "Notice: Assembling this kit may require buying a dozen wire cutters".
greyhawk
#50 Posted : 23 June 2016 09:02:56
Issue 13
Extended first planking to the bow and stern. The bow in particular isn't very easy to do as it has got some rather complex curves. Took some yelling and screaming to cow the planks into submitting into place and have them stay there.
#51 Posted : 23 June 2016 17:35:20
Yelling and screaming is better than bouncing it off a wall. LOL
Anyway the yelling and screaming seams to be producing the goods as it looks spot on. WTG
#52 Posted : 23 June 2016 21:14:33
Coming along nicely. look forward to seeing more of your build.
Ian
#53 Posted : 23 June 2016 23:00:24
Progressing nicely, looking great.....
greyhawk
#54 Posted : 24 June 2016 00:51:20
Fun fact: Next issues planks go on like warm butter on toast. Looks like this was just a problem with this specific pack on planks. Should have issue 14 done by tomorrow already
greyhawk
#55 Posted : 26 June 2016 11:34:41
Or maybe two days later. Had to build the building slip for the Royal first.
Issue 14
After extending the first planking in the mid ship to the hull bottom, the Bismarck is now 10% done. The resin part in the stern is only placed to to test fit.
#56 Posted : 26 June 2016 13:10:38
Looking good, gives me a good idea of what i have to look forward to... Will be following...
greyhawk
#57 Posted : 26 June 2016 13:12:59
#58 Posted : 26 June 2016 14:18:46
It's great to see some more progress with this beast Greyhawk, great job!!
greyhawk
#59 Posted : 03 July 2016 19:14:43
More progress incoming then.
With issue 15 more first planking is done of course.
This
was the bane of my existence, but with patience I finally got the planks to submit.
The hull bottom was pure bliss after that
Remaining holes will be closed in the next phase, then we start decking the deck.
#60 Posted : 03 July 2016 22:24:41
Now that's coming along very nicely.. Its always great to see a build once it has it skin on.... Nicely done, looking forward to the next update.
Guest (7)
5 Pages <12345>
This page was generated in 0.238 seconds.
