Issue 31 contains more planking/pins, and has instruction for the upper planking of the hull which covers Victory's Poop, Quarterdeck, Waist and Forecastle, and how to adjust the height of the planking on the Bulwarks.
When you add the final layers, you will be checking and if necessary adjusting the height of the bulwarks. You will be cutting various short lengths of planking and it pays to keep all the larger offcuts, these pieces will be useful for filling in the smaller areas when planking the lower part of the hull, the process is the same on both sides of the hull.
Start by adding two more layers of planking at the bow, measure a point 142mm back from the forward bulkhead and make a mark on the top plank, then cut a plank to reach from the mark so that it overhangs the forward bulkhead by a few millimetres.
If there is too little of the frames projecting above this plank to add another, taper this plank to 3mm at the bow end, otherwise taper it to the same amount as the planks below it.
Glue and pin the plank in place and use masking tape to hold the plank in position at the rear where there is no frame to pin to, then cut a second plank to the same length, and glue/pin into position.
Make a mark 210mm back from the ends of the planks you have just laid, cut a plank to fit from the mark to the centre of frame 26, and glue/pin into position.
Then fit another plank from frame 26 to the stern of the model, use the stern template as a guide to cut off the end of the plank that overhangs the stern.
Fit another plank from frame 25 to the stern, where depending on the tapering of the planks below, this will probably need to go to the extended section of the template.
If even part of the plank reaches this length do not cut it to the shorter part of the template. Glue/pin his plank, the aft section can be held with masking tape.
Complete the third row of planking stretching from the marked point to the stern, with two lengths of planking joining at frame 24.
Now draw a pencil mark 158mm from the front of the planks you have just laid, and measure a plank from the mark to the stern, again use the template to ensure the plank is cut to the correct length.
Adjusting the height of the BulwarksCheck the height of the completed planking around the forecastle and quarter deck, if necessary you may need to add extra strips to ensure that the planking finishes at the correct level, (don't worry if any bulwarks are higher than quoted, they are sanded to the exact size later, after the internal planking is added).
Measure from the upper side of the foremost deck support bracket to the top of the planking that forms the bulwarks.
This distance should be more than 14mm.If the bulwark is not high enough, you can correct it by adding a thin strip of plank on top.
Now check the height of the planking between frames 17 to 21. The planks should be
level with, or higher than the pencil marks you made at issue 28 step 8. If the planks are not high enough, cut a 210mm strip of plank in half lengthways and glue this to the top of the planks.
Now measure the height of the bulwarks at frame 22, it should be at least 19mm above the top deck support bracket, use the same process to raise the height of the bulwark if necessary.
Don't be concerned about the height of the highest section of planking at the stern, this will be extended later in the series.
It is a good idea to protect the stern overhang from breakage, cut a block of expanded polystyrene to fit tightly between the protruding planks and tape in place with masking tape.
Issue 32 contains planks/pins, and has instruction for the start of the planking of the lower hull, starting at the Bow.
Issue 33 contains planks/pins, and continue's the lower hull planking at the stern, a light-coloured wood filler will be required such as 'Ronseal multi purpose wood filler'.
