My latest print - Drogon from Game of Thrones Options
isherrit
#1 Posted : 29 June 2016 16:24:08
Attached a picture of my latest and largest print, model is almost full height for the printer. Took 4.5 hours but I'm well pleased with the result.
Printed in blue PLA with a slightly higher temperature (225 degrees).
Seems there are a number of key elements to getting a 'good' print.
1. Ensure extruder to print bed gap is correct
2. Check X and Y axis alignment belts
3. Check the slide rails screws; they do slacken.
Model is not of my creation; not that good on that side yet.
Credit to Michael Perez - https://www.myminifactor...rom-game-of-thrones-6660
#2 Posted : 29 June 2016 16:26:05
Well done, looks great!
kenjara
#3 Posted : 29 June 2016 16:40:35
Very nice, I am really impressed with the level of detail!
I am planning on attempting quite a tall model tonight (a knight).
Have you got a link to the file or did you make it yourself? I have a friend who loves dragons.
Out of interest what made you raise the temperature so high?
Shane
isherrit
#4 Posted : 30 June 2016 09:11:20
Hi kenjara , I've updated my entry to include the link to the file; it is just a bit bigger than the capacity of the printer but rescaling it sorted that out. The temperature increase was a test on my part to see if the first couple of layers stuck to the print bed. It was printed in PLA without raft or brim.
kenjara
#5 Posted : 30 June 2016 12:28:42
Thank you for the link, I will print a copy for my friend.
Did you see any noticeable difference by increasing the temperature?
I am certainly having better prints with 220 over 200 degrees. I think it depends on the make and type of PLA a bit too.
My friend is always print PLA at 195 degrees.
I have also been playing with various settings to improve the first few layers. Did you see my post about increasing the amount of times the printer creates a skirt around the object.
This has greatly improved my prints as it ensures the printer is applying the filament consistently before getting on to the actual model.
Thanks,
Shane
