5 Pages «<345
Dokta´s McLaren MP4/4 Options
frah2o
#81 Posted : 06 July 2016 11:23:30
DaDokta wrote:
Yeah, it`s a big one!
Yesterday i attached some decals to the Chassis:
Unfortunately one of the "powered by Honda" decals wasn`t of the best quality - have to live with that (and display the car from the left side!).
One question:
Should i put a layer of clear varnish over the decals? Normally i would do that, but as the chassis is varnished already, i`m not so sure.
Thanks!
Quote the same questions. I also purchased the Autograph Decals. I would know if once fitted, i must spray clear coat on the body. I use Tamiya TS 13 clear gloss
DaDokta
#82 Posted : 06 July 2016 13:54:08
Thanks Mr.T - so i`ll leave it as is!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#83 Posted : 06 July 2016 13:54:33
Hello Walter,
I agree with Tomick, if you are happy with the finish as it is, then it's good enough? The other option if you aren't happy, might be to use a model specific wax polish but tested first on an inconspicuous area, though to be honest I wouldn't even bother with that as the bodywork looks fine to me.
Kev
DaDokta
#84 Posted : 11 July 2016 10:04:49
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#85 Posted : 11 July 2016 10:12:19
You have achieved a fabulous end result to your build Walter, you should rightly feel very proud - very well done indeed!!
Kev
#86 Posted : 11 July 2016 13:23:55
Lovely job Walter.
You've done a splendid job with decals, the overall finish Is stunning! I'm sure this will get lots of attention once it's on display in its case
DaDokta
#87 Posted : 12 July 2016 14:02:50
Thanks guys!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#88 Posted : 05 July 2017 06:52:35
Hi guys!
As all my photos were cancelled by photobucket. I re-attached some of them - but only the more important ones.
Therefore i would like to provide a link to all the pics of this build:
DaDokta`s MP4/4 Gallery
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
5 Pages «<345
This page was generated in 0.062 seconds.
