Bow planking Options
riff-raff
#1 Posted : 08 November 2010 18:31:33
http://forum.model-space...uk/resource.ashx?a=1085
Looking at the image above (from Tomicks build) there is plenty of Rib to attach the top two planks too. On my build there is barely enough to add the first plank. I put this down to not tapering enough as I went along.
It is too late to do anything about that now, but what I need to know is: are the planks at the bow section supposed to be sanded down to the level of the ribs?
(I am painting my Victory so I'm not too worried about the plank line showing)
Thanks in advance
Built:
#2 Posted : 08 November 2010 21:16:06
Can you post a photo of your build?
riff-raff
#3 Posted : 09 November 2010 14:46:40
As you can see in the images there are no ribs at the bow section to build the last planks on to. If I lay a plank along the tops of the 3rd row of gun ports the level of planks looks good.
The stern area is fine
Built:
#4 Posted : 09 November 2010 15:34:10
Have you checked the measurement of the interior bulwark height at the bow as per step 1 of page 13, which to the top of the plank needs to be over 14mm.
If it is (with just the single plank in place) then all leave as is, if not you'll need to add a second strip to get the height up to the minimum height of 14mm, though in your case there will not be any frame to secure the strip to other than the plank below.
riff-raff
#5 Posted : 09 November 2010 18:01:42
Hi Tomick
I have just checked the top section of Rib 12 (not the very top but the long section) and I am 17mm to the top of the last plank I added.
Is this the area you said should be over 14mm?
Thanks
Built:
#6 Posted : 09 November 2010 18:03:41
Correct, so leave as is.
riff-raff
#7 Posted : 09 November 2010 18:05:17
Thanks Tomick
I was getting a little worried. I will continue on the other side now I can sleep easy BigGrin
Built:
#8 Posted : 09 November 2010 18:27:19
Night-night BigGrin
#9 Posted : 09 November 2010 21:51:17
patience of a saint tomick,patience of a saintFlapper
#10 Posted : 09 November 2010 21:56:41
Hi Karl, did CMB sort your Lathe out?
riff-raff
#11 Posted : 09 November 2010 22:15:04
What's that supposed to mean?
Built:
riff-raff
#12 Posted : 10 November 2010 20:53:31
Karl113 wrote:
beg yer pardon,that question you asked tomick was asked 20 times to tomick already,and he is still as polite as ever,which is more then Ican say for you!!!!
Riff-Raff Wrote:
In what way was I impolite? I gave as much information as I could with my question. I also used my manners. I also said thank you three times. I didn't poke my nose in where it was not asked for did I?
Built:
riff-raff
#13 Posted : 10 November 2010 20:54:34
I didn't ask Tomick - I asked the group as a whole. If you knew the answer then why didn't you reply??? If other people helped other people then Tomick would have more time for other peoples problems.
I didn't asked you to be-little me in a post nor do I appreciate your response. If you don't like something that I ask then keep your mouth shut or at least your fingers to yourself.
Since your comment I have backtracked through some of your posts and not a lot of help is offered at all from you.
I have not responded to any of your posts in the negative so why do you respond to mine in such a manner??? by the way this isn't the first time that you have acted this way to me.
If this is the response that I get from asking a question, even if it has been asked before, then you can shove your forum where the sun does not shine. If a question has been asked several times before then where is the FAQ thread? Let the forum that is there to help people who have questions stand only for those that know what they are doing.
No wonder people are leaving this forum if that's the amount of respect you get.
I have also posted this in the main thread - it will also be the last thing, along with a lot of other amature builders, that do will post.
Built:
This page was generated in 0.073 seconds.
