Using spool less filament Options
kenjara
#1 Posted : 15 July 2016 07:54:40
Before I finished building my printer I was lucky that I had been given a spool a filament from a friend and had no use for the samples.
A while a go I saw the white sample and thought it would be great to print a space shuttle with so I set it up and about an hour into the print it knotted and jammed.
The fact that the filament was not on a spool was certainly the cause of the filament knotting. I had already tried to put it on an empty spool but it wasn't having any of it.
Since then my printer has been consistently blocking about 20/30 mins into a print. If I remove the filament the feeder will still extrude normally so I am thinking its the hot end.
No amount of playing with the bed has made any difference as after days of fiddling I can only get back to where I was after the filament knotted.
I am now at the stage where I need to take the feeder and hot end apart to inspect and clean.
So if you are trying to use the sample filament I would suggest you sit with it and give it a hand feeding as it's bound to knot up and block otherwise.
On the bright side I am getting good at making micro adjustments to the bed and have learned a lot about configuring the printer.
kenjara
#2 Posted : 18 July 2016 12:30:59
I have now fixed my printer issues. Last night I took the feeder off of the back of the printer to inspect and clean it.
I cleaned the bearing on the extruder arm and the drive roller. The drive roller had a fair amount of PLA bits on it.
The thing that appears to have caused my issue was the tightness of the screw which attaches arm onto the feeder housing. This is the long screw that goes through the arm then a spacer and screws into the housing.
When I took everything apart it was very loose, everything else seemed fine.
After tightening this up and cleaning the parts I put everything back together and it worked right away.
This is great as the very thing that made me go for this build is I wanted to learn the ins and outs of a 3D printer and how to fix them so I am glad my first crack at solving an issue went so well.
I did waste many evenings playing about with the bed but now I know what to look for I should be able to get to the bottom of the issue quicker.
My first attempt to print after putting the feeder back on.
#3 Posted : 18 July 2016 12:38:23
More cool goodies from you.
It's a very good idea for regular housing keeping with any 3D printer.
This page was generated in 0.093 seconds.
