Frame for making 'gun ports' Options
jeff averre
#1 Posted : 12 November 2010 23:12:19
Could save a bit of boring monotonous work by mass producing the 'gun ports', I don't have the correct size wood for the ports so used what I have for a practice! I had some 10mm square section, glued it to a a piece of wood and cut gaps leaving 10x10mm squares, I found that they were too high but rather than try and cut them down I'll just use some packing so that the frames are not at the base of the squares, it will also make it easier to get the frames off the jig.
Anyway, just an idea you may want to try!
It wont be long before we start these.
Jeff
ArtfulBodger
#2 Posted : 13 November 2010 10:25:30
That's clever. I'd never have thought of that; do you mind if I pinch it?
Well Done.
ArtfulBodger
Previous Build:
HMS. Bounty
RussG
#3 Posted : 13 November 2010 14:12:50
Great idea that Jeff. Has anyone any idea what is being supplied for the gun ports and there overall finished size? BigGrin
Happy Building, Russ
Zeptrader
#4 Posted : 13 November 2010 19:34:35
wait til next week, but my guess (holds breath) 1mm framing equals a 10mm gun port.
This page was generated in 0.535 seconds.
