5 Pages <1234>»
OldSid's D51 Build Diary Options
#21 Posted : 18 July 2016 21:59:09
You are really chugging along with this build oldsid. I really enjoyed building mine.Lots of stuff to do in each months parts.
#22 Posted : 19 July 2016 13:31:41
Looks like you're off to great start oldisd and your job paint job looks nice and neat too, great job.
I bet it took a lot of patience installing all those tiny rivets!
oldsid
#23 Posted : 20 July 2016 22:06:15
Painted Cylinders. Installed the Motion Frame and Suspension Front and Back. It was quite a struggle, working with the tiny bushings, screws and nuts. I had quite a few two steps forward and one step back because I wasn’t paying enough attention to the detail on the springs.Had a couple backwards so had to disassemble and do it over again. And then to top it off, when I got it all installed, I found a bushing on the bench so a search to find out where it was missing and then take apart a few more things to find where It was supposed to go and then put it together again. Ready to paint now.
#24 Posted : 20 July 2016 22:34:15
Hi Sid
Your doing a grand job, hope you got your paint from the Uk now. Keep the updates coming.
oldsid
#25 Posted : 22 July 2016 01:36:38
Thanks Andy. I got impatient and gave up waiting for the paint from the UK. In fact it just came today. I ended up buying some paint from off the shelf, it's a little darker than I would like but I thing it will look ok. The Color is Canyon Black Primer and Paint. The small parts and running gear tho is ALC Stainless Steel that I got from Horizon Hobby.
oldsid
#26 Posted : 22 July 2016 01:38:07
More Paint and first 4 Drive Wheels installed. Small parts painted with ALC Black Base and ALC Stainless Steel.
#27 Posted : 22 July 2016 20:53:07
Coming along nicely and nice work
oldsid
#28 Posted : 22 July 2016 22:07:18
All 4 wheels and Coupling Rods Installed
#29 Posted : 22 July 2016 22:13:15
Looks great.It really starts to feel heavy at this stage of the build
#30 Posted : 22 July 2016 22:54:09
Think you're doing a great job on this, looks fab....
#31 Posted : 23 July 2016 12:11:27
Lovely work so far Sid, I can imagine that it's pretty weighty by now
oldsid
#32 Posted : 25 July 2016 04:05:37
Installed the Valve Gear and did some touch up paint here and there. Adjusted Eccentric Arms and checked out the running gear to see if everything ran smooth.
#33 Posted : 25 July 2016 13:04:31
Your really steaming along now Sid, nice work.
oldsid
#34 Posted : 28 July 2016 19:22:57
Been a while since I posted on here, so to show I am still working on here goes. I have come to the conclusion that I am a lousy painter, but maybe when I am done it will look ok. Firebox and boiler added to the smokebox. Six bands installed with tiny bolts and nuts. (Amazing, didn’t lose any)
#35 Posted : 28 July 2016 20:52:20
Looks good to me
oldsid
#36 Posted : 28 July 2016 23:07:00
Thanks Andy, You're being kind.
oldsid
#37 Posted : 28 July 2016 23:08:00
Sand Dome and Steps Installed to Boiler. Next comes the Sand Pipes — OH Joy!!
oldsid
#38 Posted : 29 July 2016 22:20:00
Sand Pipes and Lower Firebox installed.
#39 Posted : 29 July 2016 22:54:09
Hi Sid
Looking good and by the way did you remember to offset the bolt on the boiler ring next to the firebox by about half an inch otherwise it will destroy the silicon tube motor joint the first time you start her up.
#40 Posted : 29 July 2016 23:47:14
Lovely progress, looking good.....
Guest (6)
5 Pages <1234>»
