greg francis Options
greg francis
#1 Posted : 21 July 2016 06:40:56
Rank: Beginner Level 1
Gregs Build. I am a little confused with fitting the 16 round frames starting with fitting them in the holes on the front of the forecastle. All the rings I have received are 12mm dia all the holes that these are to be fitted are 9mm, I dont think there is enough space to take out to fit these.Nowhere does it tell to take out wood to fit these rings.
#2 Posted : 21 July 2016 07:17:20
Hi Greg . The gunport rings are fitted to the outside of the forecastle so no need to open the holes.I filled the the rings down as they looked a little to thick and they stuck out to much. Hope this helps rgd Martyn
#3 Posted : 21 July 2016 09:36:20
Hi Greg, you may find this link to my build useful. As Martyn says, don't enlarge the gun port holes, glue the rings centrally over the holes.
http://forum.model-space...ts&t=5013&p=119
This page was generated in 0.358 seconds.
