You'll find this Kyosho engine PDF useful when it comes to running the engine and break-in.
The cylinder head differs on our F1 version, but basically it is the same engine.http://www.kyosho.com/jp...74023_gx21_engine_pt.pdf
I don't know what happened yesterday but all the fuel just leaked out from the bottom. I couldn't see a leak of anything. Im gonna have to strip the tank and engine clean it all up and re build it.
It's so upsetting. I thought i was there. After 2 years.
Need to get it fixed. Otherwise it will be a display model 🙁
You need to locate where the fuel has leaked from
