21 Pages «<1415161718>»
#301 Posted : 08 August 2016 21:21:28
This looks fantastic Andy, lots of detail to look at and I love how you've gone with the partly loaded torpedo!
#302 Posted : 08 August 2016 23:11:00
kpnuts
#303 Posted : 09 August 2016 08:11:49
This is looking really great.
#304 Posted : 09 August 2016 13:08:27
Hi Andy.
Looking really great. The colour going on are really starting to show what she is going to look like when you finish. look forward to the next update.
Ian
#305 Posted : 09 August 2016 21:51:13
Thanks everyone for your comments and looking in
#306 Posted : 12 August 2016 14:56:47
Well she looks the business Andy! will you be adding any figure`s to this one ? regards Phil
#307 Posted : 12 August 2016 19:07:44
Hi Phil
No figures planed but she will be fully armed with two 20mm and a 40mm + torpedoes and depth charges on the racks.
#308 Posted : 21 August 2016 17:29:55
Hi All
Made up some lockers in the usual way by making moulds and casting the blocks, I then added the mounting girders and plasticard lids. The central lift off panel has had the two hatches added along with the deck slats and the two half moon sections at the edges. The three exhaust stacks are now fixed in place. All the lockers and fittings on the central section including the guns are just dry fitted for now.
One side of the hull has had the holes marked out ready for the rails and the torpedo rails have also been fixed in place. still need to mark out the other side and add some more detail. More soon.
#309 Posted : 21 August 2016 17:52:53
Its all filling out now with the deck details going on.
Looks a wonderful model and should look brilliant when you get it into the water.
#310 Posted : 21 August 2016 22:21:56
Superb work as usual Andy, with all the deck furnishings going on its looking pretty awesome
#311 Posted : 22 August 2016 00:09:07
Looking fab Andy, going to be one impressive beast when done.... Very well done, look forward to your next update...
#312 Posted : 22 August 2016 00:23:05
I forsee a lot of dropped jaws from envious boaters one this beauty hits the water.It is stunning
#313 Posted : 22 August 2016 02:15:24
Can`t wait to see a video of this beast opened up on a stretch of water.
Coming on a treat.
WTG Andy.
#314 Posted : 22 August 2016 08:30:41
Beautiful job Andy, she's really starting to look the part.
#315 Posted : 22 August 2016 09:07:47
Just get`s better with every update outstanding! regards Phil
#316 Posted : 22 August 2016 10:40:34
Fantastic work as always Andy, the detail going into your build is top drawer and I can see this being a talking point at you local boating lake!
#317 Posted : 22 August 2016 10:51:09
Hi Andy.
looking really fantastic. some nice detail going onto the decks.
look forward to seeing your next update.
Ian
#318 Posted : 22 August 2016 22:28:27
Thank you everyone for looking in and your comments, all are much appreciated.
#319 Posted : 29 August 2016 18:05:37
Hi All
The fittings kit came with a carly type float and a rubber dingy, I decided not to use the dingy so needed more carley floats so another mould was made and a couple more cast. The ariel masts have now been added to the Skullcap. after that the two railings were added to the main hatch cover which was then sprayed up with Schnellbootwiese. After the paint was dry the walkways were painted grey to match the other decks.
Next the various lockers/binicle and guns were sprayed up and attached to the main hatch. The guns still need some more coats of paint but I have run out and have ordered more. The two stern hatches have been made up now the flat one at the rear is simply the cut out piece from the deck with a plasticard surround added along with some plasticard rivets made on my rivet maker. The second rear hatch has more going on and has been built up like the main hatch cover still more to add here and on the stern in general.
The last pics are of the 37mm gun with its mount being sprayed up. I will add that all the spraying has been done with the Badger 200 airbrush and all done without any problems, On sale in the online shop here:-
http://www.model-space.com/gb/airbrush-set.html
More soon
#320 Posted : 29 August 2016 18:09:41
Not be long now Andy you`ll be able to launch those torpedo`s and a quick getaway LOL great job .....regards Phil
Guest (14)
This page was generated in 0.301 seconds.
