Problem with z access connection Options
Nfrichards
#1 Posted : 10 August 2016 11:20:43
Rank: Beginner Level 1
Groups: New Members, Registered
Having completed the id box printer. I went to test the configuarion of the motors and have come across an issue.
when I connect the z axis motor to the connector for the z access the motor does not run through the software. The motor is ok because it work when I connect it to the x or y connector.
Any suggestions
#2 Posted : 10 August 2016 13:07:15
It sounds like you may have a cracked circuit board. test another motor in the Z axis socket, if it does not work then it ths the which needs replacement.
Nfrichards
#3 Posted : 10 August 2016 14:43:49
Just tried another motor connected to the z axis connector and that does not work either. How do I go about ordering a replacement circuit board
#4 Posted : 10 August 2016 15:00:07
You will need to provide your Subscription reference and the relevant stage number which the particular board you need is part of, but refer to it as an issue number rather than stage number.
Contact: 0333 300 1516 (8am - 5pm) Mon- Fri
Or email: sales@model-space.co.uk
Be gentle when fitting the circuit boards as they are prone to crack if too much pressure is applied.
This page was generated in 0.091 seconds.
