Rear diff grease Options
Steve279021
#1 Posted : 12 August 2016 22:01:25
I have just received pack 11. This is where you put the top of the diff case on. It says to put grease on the ring gear on the diff before you put the top on. The problem is I used all the grease in the last stage inside the diff case. Should I Open the diff up and remove some of the grease as I might have put to much in or should I just get some more?
Dodge charger build complete
Senna lotus 97t complete
#2 Posted : 12 August 2016 22:17:23
Hi Steve
You could remove some grease if you want but I would just buy more as after running the car for around 10 tanks the grease should be removed as it will contain any bits of metal from the running in of the diff's and replaced. Any good r/c car model shop will have replacement grease or there is plenty on fleabay link below:-
http://www.ebay.co.uk/sc...iff+grease&_sacat=0
Steve279021
#3 Posted : 13 August 2016 11:32:20
Is that stuff on ebay the same as the kit stuff?
#4 Posted : 13 August 2016 12:00:50
Its a diff grease that will be the equivalent of that supplied with the kit
Steve279021
#5 Posted : 13 August 2016 19:47:53
Ok. Cheers Andy. I will get some.
This page was generated in 1.300 seconds.
