 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,503 Points: 4,421 Location: Essex
I have just received pack 11. This is where you put the top of the diff case on. It says to put grease on the ring gear on the diff before you put the top on. The problem is I used all the grease in the last stage inside the diff case. Should I Open the diff up and remove some of the grease as I might have put to much in or should I just get some more? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
Hi Steve You could remove some grease if you want but I would just buy more as after running the car for around 10 tanks the grease should be removed as it will contain any bits of metal from the running in of the diff's and replaced. Any good r/c car model shop will have replacement grease or there is plenty on fleabay link below:- http://www.ebay.co.uk/sc...iff+grease&_sacat=0
Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Is that stuff on ebay the same as the kit stuff? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Its a diff grease that will be the equivalent of that supplied with the kit Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Ok. Cheers Andy. I will get some. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
