Display Body - No Head? Options
Chasecar
#1 Posted : 14 August 2016 08:06:58
After many months I'm still working through the building of my RB7 with much joy. I did choose to go a slightly different way with the assembly and put the running gear together and then all the body work.
I'm now at the stage to start on the display body and have read ahead to see what's involved. Is it correct that the engine head has to be removed and left off to use the display body??
Chasecar
#2 Posted : 14 August 2016 08:32:23
Correct, exactly as per the instructions, reason being that the display body won't fit if the head is left in place.
Chasecar
#3 Posted : 14 August 2016 08:42:08
Thanks Mr T,
I guessed as much but had to ask.
Bit of a shame as it's that stunning redhead that sets it apart and I'm sure I can do something better that a rubber band and piece of plastic.
Got some thoughts already if I come up with something I'll post it in my diary build.
Chasecar
This page was generated in 0.658 seconds.
