Homemade super glue applicator Options
#1 Posted : 18 August 2016 11:16:49
This a simple home made tool I use for applying thin super glue (can also be used with liquid poly).
All you need is a sewing needle and a length of barbecue skewer (or thin dowel). Pic.1.
You take the needle and cut through the eye with a pair of side cutters, Pics 2 & 3.
You then insert the pointed end of the needle into the end of the skewer - it is safest to drill a pilot hole slightly smaller than the diameter of the needle first so as not to split the wood. Alternatively you use a pin vise to hold the needle, Pics 4 & 5.
You then just dip the cut end of the needle into the glue and apply to the part being glued.
The smaller the needle used the less glue is applied and the handle length can be made to suit the jop at hand - useful for getting into confined areas and when rigging ships.
I usually keep 2 or 3 different ones and if the super glue dries in the cut eye you just need to dip into acetone for a couple of minutes and wipe clean - I have been using the same ones for the last 18 months.
I hope people find this useful
pemberg attached the following image(s):
michu
#2 Posted : 18 August 2016 11:33:37
That's a great tip, I think it's even better than most of the commercially available applicators I've seen as it's easier to get the glue to flow (other I have seen have a full loop at the end which keeps the glue in). BTW, if you don't have acetone handy, it should be enough to just pass the end of applicator through a flame of a lighter, it will burn the CA away.
Happy building :-)
#3 Posted : 18 August 2016 13:14:33
Brilliant tip Graeme raiding the wife's needle box as we speak lol
#4 Posted : 18 August 2016 13:16:04
Brilliant idea Graeme! just made 3 different sized ones......regards Phil
#5 Posted : 18 August 2016 13:44:59
Hi Martyn, I did mean to put in a warning about asking the wife first!!!
#6 Posted : 18 August 2016 14:33:26
Top tip Graeme
#7 Posted : 18 August 2016 14:33:30
Excellent tip and worthy of your know how medal.
#8 Posted : 18 August 2016 15:24:04
Really good idea.
I guess the only thing to add is watch your eyes when chopping through that needlecend in case it goes "supersonic".
Will give this a try myself because up until now i have used a cocktail stick and to to any good effect and your idea is a lot lower cost than buying the commercial version.
Thanks for sharing.
#9 Posted : 18 August 2016 15:33:02
I agree, a very useful tip especially as it can get into tight spaces and hold a good amount of glue as well. I've always used a drop of glue on the pointy end of a needle in a pin-vice, or the tip of a scalpel blade for wicking superglue into joints, etc, never thought to try your method!
A top tip, thanks for that Graeme, I'll be making a set of different sizes for myself!!
Kev
#10 Posted : 18 August 2016 17:17:02
Great idea Gramme, congrats on the medal.
#11 Posted : 18 August 2016 17:22:55
Genius!! So simple yet so effective!
#12 Posted : 18 August 2016 21:39:52
Excellent idea, guess who's going to make some.....lol...
#13 Posted : 19 August 2016 08:17:43
Thanks for the positive comments guys (and the medal). I hope you find it as useful as I have.
oledad
#14 Posted : 28 January 2019 03:56:19
Rank: Beginner Level 3
Graeme. Great tip and cost savings from buying applicators. I will making several sizes and so happy my fingers will be cleaner
Oledad
This page was generated in 1.191 seconds.
