Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
Excellent job as always, Ade. The light show in the cockpit looks great. You have definitely made a showpiece to be proud of. What will you do when this is all done? Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Well done Ade, looks brilliant, the cockpit looks stunning with or all lit up. You are now way ahead of my build, but looks fantastic and nice to see it almost complete. Keep up the good work Ade. Mark Regards Markwarren (Mark) Admin
Joined: 25/05/2015 Posts: 66 Points: 204 Location: Minneapolis
Nearly there. Looks amazing. Hard to believe you can crank out all the lovely paintwork in such a short time!
That looks amazing, brilliant work!
Joined: 04/07/2015 Posts: 99 Points: 309 Location: north wales
Many thanks for the support guys... Yes life will indeed be empty after the falcon finishes ... Eaglemoss need to get their fingers out and release that delorean !!!!!
Wow - that looks absolutly brilliant. Totally love your take on a display cabinet - really suits the model. Yours takes nothing away from the model but still looks modern and smart. Looking forward to seeing how you finish up the remaining issues to your build. Happy Modelling
 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 08/05/2016 Posts: 79 Points: 251 Location: Perth, W.Australia
G'day ade, been following your excellent build ( amongst others ), before we got our mitts on this in oz. I'm in Perth,W.A...and we're currently on issue #23. Anyhoo, just wanted to say thanks to all you guys over there for explaining/advising, and being generally gracious with your help and experience ( re; pitfalls/caution 'beware' situations on this project ). Just quickly, did you notice on your #134 post, 2nd pic , that the 'headlight' resembles a heart?, goes to show people are really loving/appreciating this lady. Cheers. Ged.
ha ha ha....indeed it does ...never noticed that....yes the end is in sight for my falcon build..you guys in oz have got all this good stuff to look forward to...to ease the withdrawal symptoms of a falcon free future, I am embarking on a larger scale cockpit build so I can really go to town with lighting etc now ive got the bug !!!! when I get a bit of it done I will post some pics....glad that my experiences on this are helpful to others ...enjoy your build ade
Joined: 05/03/2015 Posts: 561 Points: 1,713 Location: South Carolina
Seeing how you are going to display this, I assume the ramp won't be used right? Why not tie into or replace the boarding ramp light for the light strip? I don't know how many volts are coming off it but it might be worth looking into seeing as it too is a light strip as well. Good job so far!
PUNCH IT !!!! adriuus attached the following image(s):
Ade, that is looking sooo sweeetttt!!!. Is it all being powered by the supplied battery box ?
Let there be light, looking good, Ade. Regards Markwarren (Mark) Admin
Joined: 16/03/2016 Posts: 122 Points: 381 Location: Layton, Utah
Sweeeeet!! That's looking sooo good Ade! If at first you don't succeed,
maybe you should skip the chainsaw juggling...
Joined: 08/03/2015 Posts: 154 Points: 435 Location: New Jersey
adriuus wrote:PUNCH IT !!!! People on Facebook have been saying that there is a dull spot between the 2 halves of the engine lights.Have you found that as well. My current builds: The Millennium Falcon, Suzuki GSX 1300R Hayabusa, Ford Mustang Shelby
A wonderful piece of work Ade, she looks amazing....  . A very impressive build... Regards Alan
Joined: 09/07/2016 Posts: 59 Points: 181 Location: Biloxi, MS
jaws062666 wrote:adriuus wrote:PUNCH IT !!!! People on Facebook have been saying that there is a dull spot between the 2 halves of the engine lights.Have you found that as well. And then it occurred to someone to cut out the walls between the two sections and run the strips so they meet in the middle without a gap!
Joined: 30/04/2015 Posts: 263 Points: 795 Location: Los Angeles
TheKraken wrote:jaws062666 wrote:adriuus wrote:PUNCH IT !!!! People on Facebook have been saying that there is a dull spot between the 2 halves of the engine lights.Have you found that as well. And then it occurred to someone to cut out the walls between the two sections and run the strips so they meet in the middle without a gap! I was kinda planning on doing just that, bringing the 2 strips together in the middle, and then adding a couple extra lights at the ends.
colson wrote:TheKraken wrote:jaws062666 wrote:adriuus wrote:PUNCH IT !!!! People on Facebook have been saying that there is a dull spot between the 2 halves of the engine lights.Have you found that as well. And then it occurred to someone to cut out the walls between the two sections and run the strips so they meet in the middle without a gap! I was kinda planning on doing just that, bringing the 2 strips together in the middle, and then adding a couple extra lights at the ends. Yeah I don't know why they are making such a big deal of it. Just cut the walls off where the two halves meet and bring the leds closer together. Shouldn't have to add any more lights at all, but I would suggest painting those recessed areas where the lights stick onto white to reflect the light more evenly. Looking good so far my friend!
hi all.....so ive been doing some modifications to the engine grille...Much as I like the glow when they are lit the look of the plastic is less than impressive as you can see in pic 1. So I decided to get out the plasticard and fabricate an engine grille that adds an extra bit of detailing to the rear ....also replaced the diffuser with another one without the transfer on it....let me know your thoughts... cheers ade adriuus attached the following image(s):
