2 Pages 12>
Tunk's build Options
tunko
#1 Posted : 24 August 2016 02:17:16
For goodness' sake. I have been watching this forum for a while now, both before and after beginning my Millennium Falcon build. I have been extraordinarily humbled by looking at the build diaries here. I am unashamed to say that I will probably be taking more from this forum than I give, but I'll try to contribute...
tunko
#2 Posted : 24 August 2016 02:23:12
One of the first mods I made was to correct that awful battle wound on the bottom of the cockpit fusilage. A little putty, and a lot of sanding.
tunko attached the following image(s):
tunko
#3 Posted : 24 August 2016 02:33:00
I am using both the Paragrafix Cockpit and Hold modifications. After looking at the wonderful creativity you guys have demonstrated using the stock cockpit and scratch mods with LEDs and fiber optics, I am convinced I could have lived without the photoetched cockpit. But I did have fun with my vinyl cutter framing the cockpit door...
tunko
#4 Posted : 24 August 2016 02:40:04
I thought the Paragrafix hold floor was the most detailed, so I went with that. But that back corner of the hold has nothing in it! Besides a few Shapeways containers to be added later, I took a page from your guys' books and did a little scratch building. As I said, I have been watching this forum for a while. Here's my start on that empty hold corner. I plan to take the hold apart and add more modifications, now that I have seen the magic done by others here.
tunko
#5 Posted : 24 August 2016 02:47:13
Because I used the Paragrafix Hold photoetch set, I had some bits left over. I was careful in removing the front of the control console, so the console face remained fairly intact. After a little painting and a piece or two of vinyl, I spruced up the side of the bunk in the hold. The bits are, as I said, from the original front of the command console.
#6 Posted : 24 August 2016 22:09:41
Nice work, love what you have done with the cockpit hull damage. I look forward to seeing your progress.
scraperjawa
#7 Posted : 24 August 2016 22:45:28
You have made a very nice start to your build. I like how you have repurposed the command console. I might even steal that idea from you. Keep up the good work and ideas.
Stephen
Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
tunko
#8 Posted : 25 August 2016 02:33:14
Thank you for your kind words. I am trying to scratch build a chair for the command console in the hold. Cut, chop, sand, glue. I'm not sure how well I can do it, but I know from this forum that it's possible.
tunko
#9 Posted : 25 August 2016 02:35:59
And some added detail...
tunko
#10 Posted : 25 August 2016 03:03:10
Thank you all for the encouraging comments. What I have liked most hearing is how builds have evolved from initial expectations. After messing with a few things, lurking in the forum, and seeing what has been done, I have come to realize that there is no such thing as an uncorrectable mistake. This knowledge is what lets you take a drill to your $$$ model. Mental freedom. Thank you all for that.
infidex
#11 Posted : 25 August 2016 05:31:51
Looking Good! Just started my build, long way to go.
Current DeAgostini Model Space Builds:
Millennium Falcon; Sovereign of the Seas, Ford Mustang Shelby
Current "Other" Model Builds:
Bandai 1/12 C-3PO (Japan Import); Revell 1/48 X-Wing "Master Series"
On The Shelf Waiting to Be Started:
Revell 1/72 Millennium Falcon "Master Series"; Bandai 1/12 Boba Fett; Bandai 1/72 Y-Wing Star Fighter; Bandai 1/72 A-Wing Starfighter
#12 Posted : 25 August 2016 08:32:30
Your modifications are taking an already very detailed kit to a whole new level.
Looks excellent what you have done so far.
#13 Posted : 25 August 2016 12:33:39
Really nice work with the chair.
There is so many customisation options for this build that it could keep you busy for a long time. It's really cool watching how other people are tackling their builds.
Look forward to seeing more.
tunko
#14 Posted : 26 August 2016 19:39:38
The encouragement is very much appreciated. I't less scary when you know you have an able resource for help and advice. I finished chair construction, and primed it.
tunko
#15 Posted : 26 August 2016 19:42:23
I also thought I'd begin construction of an equipment bay, the through the tiny doorway of the hold. After a little drawing and measuring, I went to the vinyl cutter. I find the self-adhesive vinyl is great for making templates and cutting guides.
tunko
#16 Posted : 26 August 2016 19:44:55
I forgot the images to the last post. First the vinyl, then placed onto the plastic sheets.
tunko
#17 Posted : 26 August 2016 19:47:47
I know. I can't count. I cut another set of vinyl templates and cut the final wall. Test-assembled with tape and fit into place. Halfway through I thought maybe I should have tried a cardboard mock-up first to test the dimensions, but it worked out OK.
#18 Posted : 26 August 2016 20:25:09
Excellent work, your mods look fab....
GoofyFoot
#19 Posted : 26 August 2016 20:51:46
Very nice custom mods you've got going there!
If at first you don't succeed,
maybe you should skip the chainsaw juggling...
tunko
#20 Posted : 26 August 2016 21:09:00
Thank you all. Check out the base of the chair. It's Lego! I have a feeling this won't be the last Lego either...
2 Pages 12>
This page was generated in 0.255 seconds.
