Joined: 24/08/2016 Posts: 45 Points: 138 Location: Maryland
For goodness' sake. I have been watching this forum for a while now, both before and after beginning my Millennium Falcon build. I have been extraordinarily humbled by looking at the build diaries here. I am unashamed to say that I will probably be taking more from this forum than I give, but I'll try to contribute...
One of the first mods I made was to correct that awful battle wound on the bottom of the cockpit fusilage. A little putty, and a lot of sanding. tunko attached the following image(s):
I am using both the Paragrafix Cockpit and Hold modifications. After looking at the wonderful creativity you guys have demonstrated using the stock cockpit and scratch mods with LEDs and fiber optics, I am convinced I could have lived without the photoetched cockpit. But I did have fun with my vinyl cutter framing the cockpit door... tunko attached the following image(s):
I thought the Paragrafix hold floor was the most detailed, so I went with that. But that back corner of the hold has nothing in it! Besides a few Shapeways containers to be added later, I took a page from your guys' books and did a little scratch building. As I said, I have been watching this forum for a while. Here's my start on that empty hold corner. I plan to take the hold apart and add more modifications, now that I have seen the magic done by others here. tunko attached the following image(s):
Because I used the Paragrafix Hold photoetch set, I had some bits left over. I was careful in removing the front of the control console, so the console face remained fairly intact. After a little painting and a piece or two of vinyl, I spruced up the side of the bunk in the hold. The bits are, as I said, from the original front of the command console. tunko attached the following image(s):
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,385 Points: 22,462 Location: Northamptonshire, England
Nice work, love what you have done with the cockpit hull damage. I look forward to seeing your progress. Mark Regards Markwarren (Mark) Admin
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
You have made a very nice start to your build. I like how you have repurposed the command console. I might even steal that idea from you. Keep up the good work and ideas. Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Thank you for your kind words. I am trying to scratch build a chair for the command console in the hold. Cut, chop, sand, glue. I'm not sure how well I can do it, but I know from this forum that it's possible. tunko attached the following image(s):
And some added detail... tunko attached the following image(s):
Thank you all for the encouraging comments. What I have liked most hearing is how builds have evolved from initial expectations. After messing with a few things, lurking in the forum, and seeing what has been done, I have come to realize that there is no such thing as an uncorrectable mistake. This knowledge is what lets you take a drill to your $$$ model. Mental freedom. Thank you all for that.
 Rank: Semi-Pro Level 1   Groups: Registered
Joined: 22/08/2016 Posts: 56 Points: 164 Location: Tyler, Texas
Looking Good! Just started my build, long way to go. Current DeAgostini Model Space Builds: Millennium Falcon; Sovereign of the Seas, Ford Mustang Shelby
Current "Other" Model Builds: Bandai 1/12 C-3PO (Japan Import); Revell 1/48 X-Wing "Master Series"
On The Shelf Waiting to Be Started: Revell 1/72 Millennium Falcon "Master Series"; Bandai 1/12 Boba Fett; Bandai 1/72 Y-Wing Star Fighter; Bandai 1/72 A-Wing Starfighter
Your modifications are taking an already very detailed kit to a whole new level. Looks excellent what you have done so far. Happy Modelling
Really nice work with the chair.
There is so many customisation options for this build that it could keep you busy for a long time. It's really cool watching how other people are tackling their builds.
Look forward to seeing more.
The encouragement is very much appreciated. I't less scary when you know you have an able resource for help and advice. I finished chair construction, and primed it. tunko attached the following image(s):
I also thought I'd begin construction of an equipment bay, the through the tiny doorway of the hold. After a little drawing and measuring, I went to the vinyl cutter. I find the self-adhesive vinyl is great for making templates and cutting guides.
I forgot the images to the last post. First the vinyl, then placed onto the plastic sheets. tunko attached the following image(s):
I know. I can't count. I cut another set of vinyl templates and cut the final wall. Test-assembled with tape and fit into place. Halfway through I thought maybe I should have tried a cardboard mock-up first to test the dimensions, but it worked out OK. tunko attached the following image(s):
Excellent work, your mods look fab....
Joined: 16/03/2016 Posts: 122 Points: 381 Location: Layton, Utah
Very nice custom mods you've got going there! If at first you don't succeed,
maybe you should skip the chainsaw juggling...
Thank you all. Check out the base of the chair. It's Lego! I have a feeling this won't be the last Lego either...
