11 Pages «<23456>»
Time machine 2002 Options
#61 Posted : 30 August 2016 22:28:19
Excellent work Carl, very nice touch with the gauges.....
#62 Posted : 17 September 2016 14:20:49
Thanks everyone
Test fitting the parts that go under the platform.It is still quite a tight fit.The mounting holes for the batteries and tanks are drilled.Next step is to finish the tanks with a gloss coat,attach the gauges to them and mount those first and then the batteries,feeding the wires through the base to the control boxes.
#63 Posted : 17 September 2016 21:47:38
Lovely work Carl, looking very busy now.....Blink Blink
#64 Posted : 18 September 2016 09:59:06
Superb work, the extra detail is certainly filling the base up! Nicely done!BigGrin
#65 Posted : 18 September 2016 12:34:09
Looks great Carl, really nice detailing on the battery ThumpUp Cool
#66 Posted : 18 September 2016 13:07:53
Well i think this is going to be specialDrool welldone so far CarlCool regards Phil
#67 Posted : 21 September 2016 17:37:39
Thanks guys.
There is a fuse panel that sites under the platform on the left side of the machine.
The kit has a poorly molded piece so I decided to make one from scratch using some basswood.I made the panel and then used resistors which I sprayed with brass paint and red tape to make the fuses and then I used small nails to replicate the terminals that the fuses attach to.
#68 Posted : 21 September 2016 18:07:42
That looks really cool, superb bit of scratch building and good use of easy to source parts!ThumpUp BigGrin
#69 Posted : 21 September 2016 20:01:30
Excellent work so far Carl and your scratchbuilt fuse panel looks really cool. Cool
Very well done you on your ingenuity!! ThumpUp
#70 Posted : 23 September 2016 15:02:15
Thanks guys.The base is pretty much finished.there are a couple of other additions, but I cant place them until I have the details on the top of the platform as they need to line up with those.
#71 Posted : 23 September 2016 15:24:43
There is a lot of very nice details that you are adding to this Carl, love it ThumpUp
#72 Posted : 23 September 2016 15:37:41
Very nice indeed Carl, love the combination of the stained wood and the brass, with the copper parts it all looks very Victorian and suitably antique. Very pleasing on the eye!! Cool ThumpUp
#73 Posted : 23 September 2016 16:32:08
Thanks guys,
it does have a bit of a steampunk look to it.
#74 Posted : 26 September 2016 18:45:34
There is a brass railing around the platform.The kit has brackets for the railing ,but you have to supply the railing yourself.I decided to use thick copper wire which I can bend to match the outline of the platform.I sanded the brackets so they fit onto the platform.next step is to bend the wire, fit it into the brackets and paint it all brass color.
#75 Posted : 26 September 2016 19:49:04
This is looking wonderful.
Its almost like a scratch build with all that detail you are adding.
Its going to be a unique and wonderful model when complete.
Hope it continues well for you and thanks for sharing such wonderful pictures.
#76 Posted : 26 September 2016 22:00:15
Will be a cool display peice when complete Cool
#77 Posted : 26 September 2016 22:27:35
The more I see of the build the more I'm impressed with it... looks superb...Drool Drool Drool
#78 Posted : 27 September 2016 15:21:43
Thanks everyone.More work on the rail.The copper wire is quite easy to bend, but the rail shape is a bit complex so I decided to make a guide so I could get all of the bends right.I threaded on 3 of the rail holders because once the copper is bent I wont be able to thread them all the way on.I traced the outline of the platform and used nails to hold the copper to match the curve of the platform.The next step will be to test fit this onto the platform and trim the ends.There are metal balls on the end of the rails on the movie prop and I will be using wooden beads to replicate this.
#79 Posted : 27 September 2016 15:29:14
very good work on this buildBigGrin love your extras especially the fuse boxCool the wire jig worked very well Cool regards Phil
#80 Posted : 28 September 2016 14:42:57
Cheers Phil,
I test fitted the rail to the platform.It needed a bit of fettling to get it to fit.I glued the brackets to the rail and the wooden beads on the end.Next step is to remove the rail and paint it brass colored and then refit and glue it to the platform.
Guest (6)
11 Pages «<23456>»
This page was generated in 0.446 seconds.
