12 Pages <12345>»
WW1 Road Locomotive - "captured booty" Options
#41 Posted : 31 August 2016 22:18:26
Thank you all for looking in and your comments.
Carl the fit is not bad but there are no locating pins, so glue has to be carefully done as moving the parts to line them up is a must. Plenty of clean up to do once dry to remove seams.
Kev and birdaj2, yes its a Russian figure, a tanker. It was perfect for this build being so relaxed, and also the uniform is spot on.
I have finished the figure. I had to shorten his neck, he looked like one of those boxing robots who's heads popped up! Where his hand is on his hip is a gap, there should be a holster there, but I am going to replace it with an oily cloth. I will think of something for the other hand. I will remove the star from his belt buckle and you would never know his origins!!
The smoke stack has also been trimmed back and now looks functional and not fancy. The piston block guides have been fitted and the seams filed off. As you all know until the first coat of primer goes on I wont know if any small adjustments are needed, same with the figure.
#42 Posted : 04 September 2016 11:40:59
Some more filling and sanding done, front axle is complete and the steering gear is fully functional. More of the cylinder block is done. The figure gives an idea of how big the engine is.
#43 Posted : 04 September 2016 12:51:54
Looking very nice indeed.
Especially like the detail on the figure as that face looks very sharply moulded and should paint upnreally well.
#44 Posted : 04 September 2016 15:27:33
Nice progress Daran and looking really good!!
If you are looking for something to put in the left hand of the figure, his pose is perfect to just drill a small hole between his first two fingers, add a small piece of stretched sprue and paint it to look like a cigarette? Job done!!
Kev
#45 Posted : 04 September 2016 17:12:42
Kev
Nice idea Kev, may just do that!
#46 Posted : 04 September 2016 19:00:09
Looking good from here
#47 Posted : 04 September 2016 23:33:59
Great stuff.
Liking the detail and the figurine.
#48 Posted : 13 September 2016 18:31:01
I have made some more progress on the engine. Some valves have been fitted to the cylinder block along with some pipework, and I have started on the crank and connecting rods, which by the way, is a real pain in the, anywho, I digress!!LOL I got a nice parcel from Mr Postie today, the 'booty' of this build, a cracking Howitzer!Drool I have never built anything by Merit, but judging on the box and its contents, it looks rather nice!Love LOL I will do a parts review later on.
#49 Posted : 13 September 2016 18:38:15
Looking good Nem BigGrin
#50 Posted : 13 September 2016 18:56:18
looks like tons of work, but the end result will be spectacular.
#51 Posted : 13 September 2016 19:22:22
Hi looking great nem, the gun looks to be a good kit to, look forward to more.cheers mick. BigGrin
#52 Posted : 15 September 2016 20:06:01
I had a good look through the parts for the gun and I am impressed! Excellent detail and nicely cast. Some pe parts as well. I jumped ahead in the construction to assemble the barrel. Being as I am filling and sanding parts on the engine it seemed a good idea to get the barrel out of the way.
#53 Posted : 15 September 2016 20:11:03
BigGrin Nice start with the barrelCool
#54 Posted : 15 September 2016 22:14:36
Nice work. I built the Merit 1/18 88mm flak 36 and was impressed with the quality and fit of the parts.
#55 Posted : 16 September 2016 13:46:38
I've read lots of good things about Merit kits, should be a good build
#56 Posted : 16 September 2016 13:57:50
Hi Darren.
Two nice looking kits. look forward to seeing your progress.
Ian
#57 Posted : 16 September 2016 13:59:10
Love it Darren like the start to the gun BigGrin looks to be a very detailed kit Cool regards Phil
#58 Posted : 16 September 2016 19:18:02
This has all the makings of being something special. She really is coming along beautifully.... Am certainly enjoying your work Nem...Drool Drool
#59 Posted : 16 September 2016 20:17:25
Hi all and thanks for looking in and your comments. The barrel has been sanded back and a couple of coats of primer put on to show up any defects I missed. It will be flatted back again and that will be all until it is needed. I have now started the build proper, and the outriggers have been started.
#60 Posted : 16 September 2016 21:17:40
Nice work Daran, looks a very nice kit - well done!! ThumpUp
12 Pages <12345>»
This page was generated in 0.258 seconds.
