pall malls build Options
pall mall
#1 Posted : 25 November 2010 23:19:45
Rank: Beginner Level 3
hello to you all,as you will know i dont post too much but i had to show my effort on this build so am posting some pics of my victory for your comments. please bare in mind this is my first attempt at wooden models so dont be too hard on me, but your comments and advice are very welcome.
november 25th 2010 019.jpg (3,129kb) downloaded 254 time(s).
november 25th 2010 021.jpg (3,150kb) downloaded 206 time(s).
november 25th 2010 022.jpg (3,129kb) downloaded 188 time(s).
november 25th 2010 024.jpg (3,035kb) downloaded 234 time(s).
Zeptrader
#2 Posted : 25 November 2010 23:27:03
Nothing wrong with that at all pall, in fact if this is your first then I'd be very very happy, well done mate.
Why dont your start a build diary?
Mac
#3 Posted : 26 November 2010 12:50:46
Very impressive work matey BigGrin Would be very interested in following ur build diary should u decide to do one in future! BigGrin
Pam's shipyard is closed for now no more room!
Foz
#4 Posted : 26 November 2010 13:23:17
A very nice build there. You should start the diary and keep the pics comming. Keep up the good work
pall mall
#5 Posted : 26 November 2010 22:23:48
thanks for comments but i dont think i am good enough for a build diary.just doing things my way and allways looking at other builds for ideas.this forum is a big help for people like me.BigGrin BigGrin
jeff averre
#6 Posted : 27 November 2010 01:02:25
Well done Jim, I'm in the same boat as you, (literaly), I've never built a model since I was a kid, but with a little (lot) of help from the guys on here it's amazing what you can achieve.
If you start a build diary it neednt be anything fancy, just put pics on once in a while with a few comment's, we all like to see each others handywork.Cool
Keep up the good work,
JeffBigGrin BigGrin
pall mall
#7 Posted : 29 November 2010 08:56:25
i will be posting some pics as i progress and thanks again for your encuragementBigGrin
yorkieboy1
#8 Posted : 29 November 2010 11:01:53
nothing to be ashamed of there your'e doing a damn fine job .Keep up the good work I am just in front of you have started lining the gun ports very fiddly but am taking my time with them no rush
Son of Bulwark
#9 Posted : 29 November 2010 14:49:10
Hi Pall! Cool
Just took a look at your pictures. I found a problem at the stern when you faired the hull you haven't shape the transom, reducing it so that it's flush with the false keel.
Sorry mate to have to tell you this. You will have to remove the planks at the stern and shape the transom correctly then re-plank.
I was amazed no one else spotted this before. It's a good idea to use photobucket or another photo sharing site to post your picture. You could also use this site's Attach files to post? click on the box below as you write your post and follow the step to upload your pictures.
The rest of your work is great, don't feel bad mate, these thing's happen better to fix it now than to leave it!. Your should do a build diary it shows other's your work and people can help spot any problems before it is to late.
Keep up the good work!
#10 Posted : 29 November 2010 15:32:14
In addition to what Bulwark has said, but you'll also need to add a thin strip to the top of the bow planks to bring the planking height to be level with or higher than the top of the bow frames, otherwise you'll end up with a gap when it comes to deck the bow.
pall mall
#11 Posted : 02 December 2010 22:00:20
thanks ship mates but i dont understand about the transome and the stern planks are higher than the ribs so dont understand about the decking being wrong.Confused Confused Confused
#12 Posted : 03 December 2010 11:15:18
Re the bow planking, take a look at photos 8a/8b on page 13 of issue 26, which shows that the final plank at the bow should be level with or higher than the tops of the bow frames.
Re the transom, frame 34 should be sanded so that it follows the line of the stern post, i.e. so that it is flush with the keel and not proud of it, see steps 3/4 of issue 20, your photo shows frame 34 proud of the keel.
pall mall
#13 Posted : 05 December 2010 22:34:05
thank you tomick i see what you meen now, will put that right and thanks again mateBlushing Blushing Blushing
This page was generated in 0.787 seconds.
