painting the gun supports and installing decks 6a Options
ronald305
#1 Posted : 04 September 2016 21:03:48
Hi guys and Gals I have two questions
1) which admiralty black paints do I use for the gun supports is it the dull black
2) on the second level,deck 6a how come it doesn't get glued in place like 6b does and if it does I must have missed it somewhere, even the videos doesn't show or I missed that to LOL thank you
Ronald
#2 Posted : 04 September 2016 21:39:06
Hi Ronald.
The paint used for the gun supports is the dull black. As for the decks, they are all glued in place. The way this was done was to glue the first deck section in place, the other 3 sections were simply put in place until the first section was dry. Once the first section was dry move onto fitting the second section and so on until all the sections are fitted.
Hope this helps.
ronald305
#3 Posted : 04 September 2016 22:39:31
OOH OK thanks Alan
I kind of thought so I must have missed understood as far as the second deck was concerned
Ronald
This page was generated in 0.138 seconds.
