spray painting spitfire camouflage Options
Ron
#1 Posted : 11 September 2016 13:51:42
Rank: Amateur Level 1
Has anyone the best way of spray painting the camouflage for the spitfire, are there any stencils available ? or would hand brush painting be the best way
#2 Posted : 11 September 2016 13:56:55
As mentioned in my PM, the blu-tak method is often used as seen in this video clip
https://www.youtube.com/watch?v=tECZK1SFGE8
ALW
#3 Posted : 14 September 2016 18:52:04
Hi Ron
I have found the best way is an aerosol, I use Humbrol with
brilliant results.
Also White Tack is best for masking as it doesn't leave residue.
Hope that helps.
PS you'll see the results of my spray painting in my build diary. There is a photo of the wing section in camouflage colours.
This page was generated in 0.089 seconds.
