Joined: 11/09/2010 Posts: 9 Points: -23 Location: Kent
Have started Yamoto build and will be going r.c.. I am at the stage were I need the length of the shafts and size of the props. would anybody be kind enough to give me these details. I would be very grateful as I am new to remote control and need all the information I can get.(also a bit nervous) Allen
Hi Allen,
Making R/C what is intended as a static model is a lot to take on as a first R/C model, is it your first plank-on-frame ship model?
Jinks8 is well on with converting his Yamato to R/C and will be able to point you in the right direction for what items are best suited and what he's done.
Joined: 24/01/2010 Posts: 131 Points: 398 Location: North Yorkshire FILEY By The Sea
Hi Alyvonne if you look on my build you will see what I have dune the motors are from a place called robot bits http://www.robotbits.co.uk Prop shafts from deans marine 2mm shafts can not give length of hand but get you that later http://www.deansmarine.co.uk/ The props are from prop shop 25mm 2 left ,2right hand http://www.prop-shop.co.uk/ the battery will be 14v 4 cell lipo one circuit board from Hunter Systems http://shop.huntersystems.co.uk/ Ruder servo you chose from local model shop . the battery you could use a standard 7.2v NiMH pack if I have left out something just ask and I will try my best to answer it ps the motors are 50:1 High Power Micro Motor + Gearbox £12.99 each.
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
Hi Allen I dont want to appear to be sticking my nose inbut you may want to try Action electronics. I got in touch with Dave who is the gaffa and he sorted everything out from motors to batteries wiring diagrams all he wanted to know was what size space you had to fit everything into If you look at my post of Titanic in other builds Dave did all the electronics for that and his prices are very reasonable anything he doen't do he will tell you who to contact hope this is helpful
Hi yorkiboy that is what the site is for to gather and pass on info if people did not but in or as we say stick their ore in we would not gather new skills as for my build the 4 small motors did not push the ship as expected so had to change and put 2 larger ones in. Action electronics are good have 1 or 2 of there bits in difrent ships
Thank-you one and all for your help. very greatful. I am sure I will be asking for more help soon. Thanks once again. Allen
