4 Pages «<234
mogwai honda build Options
#61 Posted : 22 June 2016 17:07:34
Looking good Mick.
#62 Posted : 24 July 2016 18:40:33
Hi thanks for looking in, and comments left, much appreciated. Oh well onto pack 22. Which sees us put the front end on.an she can finally stand on her center stand. Rest this pack mainly concentrates on the handle bars grips and levers.did have to glue throttle side on as was loose on mine.other side was fine.then it put a hose in and the cables from the clutch and throttle side.all went together well.and great quality as normal. I did push on into pack 23 by testing all the electrics works fine on mine, and sounds great.plus I fixed the fuel tank in place.that's it for now look forward to next pack.nearing the end now .cheers mick .
#63 Posted : 24 July 2016 19:54:27
Nice work and i bet you need a forklift to get the beast off the table now
#64 Posted : 24 July 2016 22:46:59
Hi Andy, thanks for looking in and your comments, much appreciated. She certainly is very heavy now.have to stand up to lift and turn her round now.cheers mick.
#65 Posted : 24 July 2016 23:31:27
Looking good Mick, strangely I had the opposite of you regarding the grips lol.
#66 Posted : 24 July 2016 23:55:28
That`s looking good Mick, nearly finished.
WTG
#67 Posted : 25 July 2016 11:57:11
Looking good Mick, she certainly is a beauty
stevegbr
#68 Posted : 25 July 2016 13:01:21
Looks fantastic mick. I am waiting for pack 11 on mine. So still a way to go yet.have you completed the stand for it.
#69 Posted : 20 August 2016 15:09:42
Hi all thanks for looking in and comments left much appreciated. Hi Steve stand is complete apart from top, and speaker grills you get in last pack. Stand starts coming from pack 16. Onto pack 23. Fitting the side stand, footrests, Lil covers for screws in headlight bracket.my footrests were Lil tight to get in, so I filed off the Lil ridges and glued them in.and then the seat base.nearly home now one more pack to come to the finish line, of what's been a very enjoyable build. Cheers mick.
#70 Posted : 20 August 2016 15:16:11
Very well put together - it looks a fantastic model.
#71 Posted : 20 August 2016 17:17:41
Looking good Mick, on the home straight now. Will get mine to same stage as yours once I'm back from my hols.
#72 Posted : 20 August 2016 22:30:00
Nearly there Mick and nice work
#73 Posted : 15 September 2016 15:47:02
Hi all thanks for looking in and comments left, much appreciated. Anyway pack 24 and the end of the road. Just the seat to push on and fit mirrors to the bike.and put speaker grill, and display top on.the left hand mirror was suppose to be a D shaped on the pin to fit the one on the handle bars, however mine was round.with couple raised bits for push fit.I had to file the raised bits off, and a flat.to get mine in.not a problem.they both needed supergluing in.as were rather loose.this has been a fun build.and gives you a superb model at the end.which I would recommend to anyone.ill put pics up in finished gallery.cheers mick.
#74 Posted : 15 September 2016 16:33:52
Nice to see her finished Mick Cool Should have mine done tomorrowBigGrin
#75 Posted : 15 September 2016 19:52:59
BigGrin Nice to see another finished and well done. The only thing the picture fail to show is its shear sizeCool
#76 Posted : 16 September 2016 13:00:33
It really is a stunning looking model, will look great on display
Geoff44
#77 Posted : 22 March 2017 17:33:20
Another great looking bike. Well done on your completion Mick. Cool Drool
BUILDING - HONDA CB750 - HAYNES V8 VISIBLE ENGINE
NEXT BUILD - JAGUAR E-TYPE
GEOFF
Guest (9)
4 Pages «<234
This page was generated in 0.229 seconds.
