Question for Tomick Options
tf5600
#1 Posted : 01 December 2010 20:06:28
hi Tomick,
I have made a slight cock up, i have started layer 9 planking instead of 8,the joints are hardly visable but still staggered. will this matter, ie will the darker wood cover the error ? where should i start layer 10 ? Or should i remove both layers and start again ? the book threw me having 9 before 8, should not be so impatient,just wanted to catch up a bit .
Ferret
#2 Posted : 01 December 2010 21:41:28
As long as you stagger the joints just carry on, though if its only one layer you might prefer to remove it and re-lay. I'm unsure what you mean by darker wood covering the error, a second darker skin is not being supplied.
tf5600
#3 Posted : 01 December 2010 22:01:23
Thanks Tomick
What i mean by the darker wood is the darker stripes between decks as in picture of model
it looks like there stuck on over the planking
Ferret
ArtfulBodger
#4 Posted : 01 December 2010 22:45:10
where did that piccome from, its amazing
ArtfulBodger
Previous Build:
HMS. Bounty
tf5600
#5 Posted : 01 December 2010 23:00:12
Artful
If you click on the HMS Victory Tab at the top of the Model Space page, then click on " View more HMS Victory pictures & info, you'll find them here, I take it they are pictures of our model ?
Ferret
This page was generated in 0.082 seconds.
