9 Pages <12345>»
Micks aka Mogwai C57 build diary Options
#41 Posted : 29 August 2016 21:54:46
She's looking fab Mick and I too like to see a diary covering each stage... Look forward to your next update....
#42 Posted : 15 September 2016 17:55:52
Looking good Mick and growing fast.
WTGBigGrin
#43 Posted : 16 September 2016 18:24:00
Hi thanks to all who looked in and left comments, much appreciated.
Onto pack 4
Stage 21 the leaf springs.
Just fixed together with screws and nuts.quite a fiddly Lil job. Be carefull with nuts, and bushes as there are no spares. Cheers mick. BigGrin
#44 Posted : 16 September 2016 18:30:43
Hi pack 4
Stage 22 the second wheels.
Just assemble and hold in place with bracket on top.just need to pay attention here to make sure things are in right place. Nice to have her resting on wheels.all I managed today.more to follow soon. Cheers mick. BigGrin
#45 Posted : 19 September 2016 20:56:08
Stage 23 the third wheel. This just putting in third wheel same as previous 2. And start on the connection rods. Cheers mick. BigGrin
#46 Posted : 19 September 2016 21:03:30
Hi stage 24. The connecting rods. Carry on putting together the rods. Just need to concentrate on what doing now. Cheers mick. BigGrin
#47 Posted : 19 September 2016 21:10:11
Hi stage 25 the valve gear. Build up the left and right valve gear assemblys. Cheers mick. BigGrin
#48 Posted : 19 September 2016 21:23:59
Hi stage 26 the motion plates.this involves putting in the reverse levers, and attaching the valve gear assemblys. Then you can test it to see if it runs smooth. Unfortunately mine did not.found one side the head of screw was hitting the second wheel. Which has removed the paint from this part of the wheel. I disassembled it and rubbed down the width of the brass bush, as they do stick out a bit.this allowed less side movement of bush.so kept the screw head off wheel. All runs very smooth now.ill just have to repaint wheel at some point. Cheers mick.BigGrin
#49 Posted : 19 September 2016 22:45:54
Hi the nut rubbing was my fault, I got the assembly wrong on the right hand side. TWIT oh well need to pay more attention.all corrected now. Cheers mick. BigGrin
#50 Posted : 19 September 2016 22:49:52
Looks like very precise work going on here, looking great.....Cool Cool Cool
#51 Posted : 20 September 2016 13:56:09
Hi thanks for comment left Alan, much appreciated.
Stage 27
The leading truck 1
Simple screw few bits together stage here.all fits well no problems. Cheers mick. BigGrin
#52 Posted : 20 September 2016 14:01:38
Hi stage 28
The leading truck 2
This just put in the Lil sliding bit into the previous assembly. This now concludes pack 4, of a very good kit.finally couple of pics of what have so far.cheers mick. BigGrin
#53 Posted : 20 September 2016 16:18:57
Looking great Mick BigGrin love all those fiddly bits don`t youLOL LOL LOL LOL Phil
#54 Posted : 20 September 2016 18:35:19
Lovely work Mick Cool
Have you knocked off the pipe that hangs from the front yet? I have, twice Cursing LOL
#55 Posted : 25 September 2016 11:28:52
Hi Phil, Dave.for looking in.yes I do like the fiddly bits Phil. Dave no not broken it yet.as I'm using epoxy on all my joints, super strong.but this part really gets in the way, and think I'd leave it off till needed, if I started again. Cheers mick.
#56 Posted : 25 September 2016 16:47:30
Hi Mick,BigGrin
Looking good , Cool Cool Cool Cool
Just received the early parts of this build, but with all the other commitments I`ve got on at the moment it`s gonna sit on the shelf for a while.
When it comes to my build I`ll be looking in on your build for guidance and tips along with the official build.
Keep up the good work and good luck.
#57 Posted : 17 December 2016 16:38:37
Hi all thanks for looking in, and comments left, much appreciated.
Onto pack 5,
Stage 29 the leading truck 3
This just involves putting together the equalising bars and leaf springs into the truck. Easy Lil start. Cheers mickBigGrin
#58 Posted : 17 December 2016 16:43:08
That s looking Great MickBigGrin really like the detail to thisDrool Drool Love regards Phil
#59 Posted : 17 December 2016 16:45:15
Pack 5
Stage 30
This sees us put the front wheels in and attach the truck to the chassis. Again simple screw together job. Cheers mick. BigGrin
#60 Posted : 17 December 2016 16:52:42
Pack 5
Stage 31
The headlamp
This just involves gluing the little handle in the smokebox door. And gluing the headlamp to the front, then feeding the bulb through. Cheers mick. BigGrin
9 Pages <12345>»
This page was generated in 0.312 seconds.
