Tools for fairing hull Options
Brian100
#1 Posted : 02 December 2010 21:51:41
Rank: Beginner Level 3
Can someone advise on the best tools for fairing the hull. This is my first build so i am aquirring tools as required. Many thanks.
Brian
Lakes74
#2 Posted : 02 December 2010 22:41:30
Rank: Amateur Level 1
Hi Brian, I used a medium sized (sponge) sanding block with changeable (velcro) sandpaper. I'm a beginner and first went for what the pro's were using, a modelling planer. But when it arrived I decided against it as i wasn't comfortable enough using it! I'd probbaly end up taking chunks out of the ribs, lol. The sanding block was great using different grades of sandpaper. To be honest it didn't take that long either.
Cheers
#3 Posted : 02 December 2010 22:55:38
take a look at these sanding blocks as recomended by mr.t www.permagrit.com
Mike Turpin
#4 Posted : 03 December 2010 00:54:13
I would second Karl's suggestion. Again on Tomick's advice I bought a small file and set of needle files from same source. As long as you are not too heavy handed they make shaping and fitting a lot easier.
Mike T
Brian100
#5 Posted : 03 December 2010 08:29:08
Thanks Mike, Karl and lake for your advice, was considering bying a modeling plane but i'll give it a miss for now.
Brian
This page was generated in 0.094 seconds.
