11 Pages <12345>»
eebygum's Soliel Royal Build Options
#41 Posted : 27 August 2016 15:35:26
Thats coming along very nicely.
Like the pre-cut gunports as that can save loads of work later on.
#42 Posted : 27 August 2016 22:22:09
Think you're doing a great job on this. She's coming along a treat and this is one build I'm enjoying following.... Very well done...
#43 Posted : 27 August 2016 22:29:30
Nicee work . Your going great guns on her. Loving your build.
Chris
#44 Posted : 31 August 2016 11:28:19
Looking a very nice clean build. look forward to seeing your progress.
Ian
eebygum
#45 Posted : 06 September 2016 22:35:12
Thank you very much for all the comments guys. Just waiting for Pack 4 to arrive in order carry on with the build, seems to be taking ages
Terry
eebygum
#46 Posted : 20 September 2016 10:19:12
Just got pack four and have a problem with the fittings of the two Bow gun ports.
eebygum attached the following image(s):
#47 Posted : 20 September 2016 11:53:46
Hiya, It is around 5-6 mm above the deck line showing. I will have a look through your pictures when I get them to load and see if I can see where the problem lies. Otherwise it would mean adding a plank in. But wait until I have looked before you do.
Chris
eebygum
#48 Posted : 20 September 2016 12:15:25
Cheers Chris
#49 Posted : 20 September 2016 19:24:40
Now you have all the Parts for Pack 4, If you look at stage 34 and temporarily fit the next gunport strip. Measure from the inside of it from the deck to the top and let me know if it is 20mm at both ends of the lowest point.
Chris
magpie1832 attached the following image(s):
eebygum
#50 Posted : 20 September 2016 20:22:00
Chris
Yes both sides are 20 mm at both places.
Terry
#51 Posted : 20 September 2016 20:31:39
Ok then all you need to do is add a tapered strip. Take a planking strip and taper it from nothing to 2-3 mm keep testing the gun port strip on top of it to get it to stick up 3mm at the front. That should then be correct for you. Luckily you can get away with a couple of mm.
Hope this helps you.
Chris.
eebygum
#52 Posted : 20 September 2016 20:50:42
Thanks Chris
I assume you mean the front gun port strip not the second one?
Thanks again
Terry
#53 Posted : 20 September 2016 20:54:08
Yeah just the front one. That should correct it for you.
Chris
eebygum
#54 Posted : 22 September 2016 13:00:54
Sorted out the forward gunports thanks to a lot of help from Chris (magpie1832)
thanks again Chris
#55 Posted : 22 September 2016 15:53:41
BigGrin Nice fix Terry looking good Cool
#56 Posted : 22 September 2016 15:54:46
Watching this build with interest.Great job so far
#57 Posted : 22 September 2016 18:46:26
Very well done Terry, nice to see you're back on track with this one....Cool Cool Cool
#58 Posted : 22 September 2016 20:54:30
BigGrin Nice work, although where the gun port hits a rib you could have marked the gun port and then rebated the rib so the gun port blank slides in side ways to fill the gun port neatlyCool
eebygum
#59 Posted : 22 September 2016 21:54:54
Thanks for the comments guys
Terry
#60 Posted : 22 September 2016 22:53:23
Glad you got it sorted Terry. Onwards and upwards now.
Look forward to seeing your progress.
Chris
11 Pages <12345>»
