Request for Mr T Options
CMB
#1 Posted : 09 December 2010 19:28:02
Hello Mr T, can you please post a picture of the stern planking on your build.
My build follows yours pretty closely but some of the planks on the stern/transom have required a lot of tapering. The first three layers of planks were fitted without to much trouble (ignore the bending) then the next two layers required tapering to about 2.5mm.Have I dropped a clanger, if so now is the time to rectify, or is this one of the possible scenarios?
Many thanks for any advice you can offer
CMB
Many thanks for promt reply.
Pictures attached as requested
CMB
CMB attached the following image(s):
#2 Posted : 09 December 2010 21:17:42
For many reasons the hull planking will differ from build to build, certainly the transom planking needs considerable tapering, it would be better if you could post a photo of what you might think is a problem with your build.
CMB
#3 Posted : 10 December 2010 10:55:02
CMB
Mr T
CMB
#4 Posted : 10 December 2010 23:10:12
Continue to taper as you go, and make sure each plank end reaches the transom otherwise you going to have to fill any shortfall.
CMB
#5 Posted : 11 December 2010 00:35:43
Many thanks Mr T for your advice.
I have after looking carefully at the pictures I submitted decided to strip back the planking and modify the fairing around the stern to allow the planks to reach the transom. This has produced a much softer curve which should be easier to plank.
Once again many thanks for your advice.
CMB
This page was generated in 0.814 seconds.
