help with warped parts Options
shaun
#1 Posted : 11 December 2010 15:56:55
Groups: Registered, registriert
hi all i need advice on straightening out warped ribs/parts Crying. i have had replacements but they are also warped been inbetween 2 speakers layed on top of each other with about 20kg on top for 2 weeks and they are still slightly warped thanks in advance for any help given.
#2 Posted : 11 December 2010 16:03:30
hi,you need to dampen them first then press them for about two days should work.
shaun
#3 Posted : 11 December 2010 16:11:48
thanks hot or cold water
benny
#4 Posted : 11 December 2010 17:46:19
hi shaun..wat i did was soak all my ribs as i recieved them in hot water for about 30 minutes,the i put them between 2 pieces of kitchen worktop,some were there for about 6-8 weeks until we recieved the decks...worked for meBigGrin ...paul
cheers benny
shaun
#5 Posted : 11 December 2010 17:56:51
ok benny thanks i will give that a try
This page was generated in 0.082 seconds.
