2 Pages <12
Not Printing Options
wickedboy11
#21 Posted : 09 October 2016 13:07:50
Rank: Beginner Level 3
thank you for your reply. I have found that you are correct with the printer waiting for the bed to warm up. i have tried to turn off as suggested but still nothing
code doesn't seem to be working
#22 Posted : 09 October 2016 15:22:38
So you turned the heated bed off in manual control and you changed the g code to M190 S0 and nothing still happens?
Does the printer home itself on the x,y and z axis?
Does repetier host show the extruder heating up OK?
If you manually extrude the filament in manual control does it come out of the print head?
wickedboy11
#23 Posted : 09 October 2016 15:53:00
i have finally got the printer to print using CuraEngine.
WHOOOOOOOOOO BigGrin
just having problems getting the print to adhere to the base.
#24 Posted : 09 October 2016 17:21:04
Did you use a raft? I would recommend using a raft for each print.
I have a pair of tweezers I use.Once I do the manual extrusion before the print starts I use the tweezers to remove the filament strand. Otherwsie this can prevent afhesion as the print head drags a piece of PLA across the bed.
The benefit of a raft is if the filament doesnt stick right away it wont affect your print because it will just be the first part of the raft that doesnt stick.
I would also make sure the temp of the extruder is at 210-220 for PLA.
#25 Posted : 09 October 2016 19:08:35
BigGrin Glad you have it sorted and its printing for you nowCool
2 Pages <12
This page was generated in 0.535 seconds.
