 Coming together nicely now Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Really looking the part now. I didn't realise how big it was until I saw your hand in the picture, its huge!
Very nice work on the replacement castings Carl, they look to be a great fit, well done. I too am surprised at just how big this model is.
Kev
Well I'm glad I stumbled onto this one, it's just incredible, what else can I say. Ken's the name modeling's the game.
Gets better and better everytime I look in, looks fab.... Regards Alan4
Started work on the petals.The upper and lower parts of the time ring have 2 rows of petals.These are made of clear resin.There was a ton of flash on the clear resin and on the parts that hold the clear parts.So I have started cleanup and test fitting of the petals.All 36 of them darbyvet attached the following image(s):
More great work Carl  thats the only problem with resin kits flash  but you`ll clean it up in no time matey  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
The supports for the petal are now glued to the center wheel and out rim.This will get a final sanding and then off to paint.There is a second ring that sits on top of this one that I am working on next and then I have to repeat the whole procedure for the lower ring. Carl darbyvet attached the following image(s):
Joined: 10/10/2010 Posts: 691 Points: 2,136 Location: Dorset
I have sussed it. I know why you are building the time machine. Once completed you are going to use it to go back and tell yourself not to build the Jupiter Seriously though this is one cracking build I shall continue to watch the build progress with interest Gil Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
That's looks not very nice Carl, the 3D printed parts look great
Really taking shape now and an interesting build, wel done so far
Thanks everyone, interesting you talk about time Gil.When I ordered the kit a couple of years ago it went missing in the mail.It somehow ended up at Paypals headquarters. Paypal refused to send it back to the sender and said it has been destroyed .Randy sent me another kit.2 years later he received the original kit in the mail.Where it had been for 2 years is a mystery.Maybe it was stuck in a time warp! Anyway the second wheel and row of petals has now been assembled and test fitted onto the first ring.next step is to paint everything and then attach the "glass" petals.These are made of clear resin. darbyvet attached the following image(s):
 Nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Cheers Andy. There is an actuator arm that attaches to each of the petals of the first ring.They are resin castings and have a pretty big pour stub.I am impressed by the molding, but getting them off the pour stub without damage proved very difficult.I was lucky to only break one out of the 18 actuators. darbyvet attached the following image(s):
Hi Carl. Your time machine is looking fantastic. very detailed build. look forward to seeing your progress Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Now I am test fitting one of the outer rings of petals.The petals are made up of a clear resin piece and the frame.of course the petals dont fit into the frames well so it has taken quite a bit of fettling to get them to fit.nest step is to do the second out ring and then repeat the process for the main ring of petals.There is still a ton of work to do here.Not sure if this will make the build competition deadline. Carl darbyvet attached the following image(s):
It'll be a shame not to hit the deadline but understandable if it means carrying on with the high standard of work you've already put in to this
Cheers Dave, I have now finished the outer rings with petals.The main rings are also done so now I have to make 18 petals to attach to the main rings and then the 2 rings on the left attach to the central ball and act as a base for the 2 rows of petals. darbyvet attached the following image(s):
Really is a pleasure to see you build this Carl  the detail is superb  as are your scratchbuilt modification`s  Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks Phil, the time rings are finished.there is a scale etched onto the rings.it was poorly defined on the resin parts so I sanded off the scale and used a decal made by a friend to make the scale.I also added copper tape around the edge of the ring. darbyvet attached the following image(s):
Guest (9)
