Build problem I need help with Options
RobT
#1 Posted : 30 October 2016 20:34:06
I have come across a problem. I fitted my first gun port fret today. I faired the frames and fitted it. However, even though it is tightly nailed in, it seems to jut out slightly above the projections as shown in the photo. However, this means that when the planking goes over it, it will be too thick and not marry up with the planks below it later on. Do I have to remove the fret and alter all the frames so the fret sits bang level with the projections?
#2 Posted : 30 October 2016 20:54:35
BigGrin Hi Rob the gunport frame is slightly higher as the first planking is 2mm thick and will match up to it so you can sand it down ready for the second planks
Hope this helps rgd Martyn
RobT
#3 Posted : 30 October 2016 21:00:35
So alls good. Lovely, cheers Martyn.
#4 Posted : 30 October 2016 21:08:42
BigGrin No problem mate Cool
This page was generated in 0.093 seconds.
