51 Pages «<1314151617>»
DaDokta`s Build Options
#281 Posted : 07 November 2016 18:09:19
Here is a listing on ebay for the dispenser.
191769808251
They are good because if you ever use all the wax you can reload them.
I have just put black wax into one that i melted down from a block and used a tealight foil holder as the mold.
DaDokta
#282 Posted : 09 November 2016 09:51:25
Thanks guys for your help!! Much appreciated!
Made some decisions:
1. Stayed with the 3mm blocks as there are no 2mm double-blocks, which i want to use at the hull side of the tackles, as in the original.
2. Get rid of the additional hooks and brass rings to make the tackles shorter.
3. Use 1mm eyebolts at the gun and 2mm eyebolts at the hull.
4. Change the attaching location of both the tackles and breaching ropes at the hull - used the instructions of the Victory Cross-Section build as guidance.
5. Attached additional eyebolt and brass ring at the gun for a slightly different route of the breaching ropes.
Here are some pics:
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
alemo
#283 Posted : 09 November 2016 10:42:07
Hi Walter,
I like what you have done and to me looks a lot better than the brass wire around the blocks. I believe that the overall appearance is most important and that you are happy with the end result.
Alec
Adapt, improvise, overcome.
#284 Posted : 09 November 2016 18:00:53
Fantastic rope work with the cannons Walter, it looks very convincing and will look quite spectacular when all the other cannons are done ThumpUp ThumpUp
#285 Posted : 09 November 2016 20:24:02
Looks great Walter, your time, effort and patience has really paid off....Cool Cool Cool ..
I find beeswax is the best method of calming down furry thread but it also has to be applied correctly. Run the thread through the wax a couple of times, then run the thread between your thumb and finger a few times. The heat from your thumb and finger warms up the wax. Cool Cool
#286 Posted : 11 November 2016 14:18:00
Lovely work there Walter, love your attention to detail. Looks great.
Garth
#287 Posted : 14 November 2016 06:44:58
Hi Walter,
The extra work you have put into the guns has really paid off - they look excellent.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
DaDokta
#288 Posted : 14 November 2016 10:56:44
Thank you all for your kind words!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#289 Posted : 28 February 2017 10:06:33
A small update regarding the guns. Didn`t have much spare time the last months.
I finished the 5 guns of the starboard-side.
The ropes look a little bit messy on purpose - as i imagine in a combat-situation they were not curled up as tidy as seen on today`s pictures.
What do you think?
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Garth
#290 Posted : 13 March 2017 15:52:27
Hi Walter,
Great job on the guns. I think they truly look the part.
Kind regards,
Garth
#291 Posted : 14 March 2017 00:28:06
Apologies Walter, I obviously missed your update.... great work on the guns, everything is looking great.....Cool Cool Cool
DaDokta
#292 Posted : 14 March 2017 13:50:08
Thanks guys!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#293 Posted : 27 April 2017 12:42:20
Hi guys,
i would like to show you what i did during the last 2 months.
First i completed the second line of guns on the upper deck.
This time i made more tidy rope-coils, made some other little adjustments.
All in all i like this side better than the first. It`s learning by doing after all!
I have plans to do a "gun-tackling"-tutorial in the how-to-sections, as it took me hours and hours of research, sorting out which additional parts to order and just try-and-error during the build to complete this task in a way i`m pleased with.
I hope you like it too :)
As always thanks for looking in!
Next time i will show you my solution for the quarter deck - as i built this again completely different than the instructions wanted me to :)
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#294 Posted : 27 April 2017 14:54:26
Good to see your getting closer to the end and she is looking great Cool
darkwoodster
#295 Posted : 27 April 2017 17:10:25
That deck is looking lovely. Very Inspiring :-)
#296 Posted : 27 April 2017 17:14:53
Some very neat and tidy work and 2 months well spent i can see.
#297 Posted : 27 April 2017 19:49:54
Your efforts have been well rewarded with the results on show.... she's looking great, very well done.....Drool Drool
DaDokta
#298 Posted : 02 May 2017 13:39:52
Thanks guys!
So next step was the quarter deck. I wanted to make the deck of 4x1mm planks of tanganyika-wood and lay them in a 3-way butting pattern.
To make that possible i first built a deck out of cardcoard with all the deck openings already cut in:
Then i copied that deck onto a 1mm plastic card, which i glued onto the deck beams (corrected in their height) after painting it black:
I always checked that the mast can be moved into the correct position!
To be continued soon!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#299 Posted : 04 May 2017 13:32:15
Unfortunately i didn`t think of looking in my books before glueing the deck in!
When checking with the original plans i noticed that the deck openings (especially the aft companionway) is completely in the wrong place, when following the instructions.
So i had to improvise:
Then finally i could start the planking -- which was pretty straight forward. I built a little jig to be able to fast-cut the Planks always in the same lenght (12cm - which would be 10m in real size)
I built in a transverse plank at the forward end of the big opening - as i saw this on a Picture of the real ship
Aaaaand done!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#300 Posted : 04 May 2017 19:55:39
Looks great to me Walter Cool
Guest (33)
This page was generated in 0.340 seconds.
