12 Pages «<23456>»
Gils HMS Victory - Cross Section Build Options
#61 Posted : 27 October 2016 20:05:00
Gil
You are enjoying this one i can see.
Not just a model but a great piece of history in the making.
Hope it continues well.
#62 Posted : 27 October 2016 22:16:51
This is really coming along very nicely Gil, you're doing a fab job.....Drool Drool
#63 Posted : 28 October 2016 10:46:59
Very nice work Gil. It's coming along.
Chris Cool Cool
#64 Posted : 28 October 2016 11:58:53
Progressing nicely, good job.
#65 Posted : 28 October 2016 13:53:53
Beautiful work there Gill, well done. Love your attention to detail.
GilShapley
#66 Posted : 29 October 2016 15:13:41
Just about to start planking the orlop and I have a question. In Issue 132 The build instructions state "Cut a length of 1 X 4 mm wood (Planking the orlop stage 1) . Is this correct as I can only find 1.5 X 4 supplied with issue 132. Is this a typo or if not with which issue was this planking supplied.
Current Build:-
GilShapley
#67 Posted : 29 October 2016 17:00:48
131 Contd - Adding the beams
As this build progresses there is no doubt that space to work will be an issue. My sausage fingers do not help. With that in mind I decided to assemble Parts 22,23,25,and 27 before gluing them to the ribs. It was easier to clamp the parts to ensure the glue would set without the parts moving. The assembled beams where then attached the ribs. The remaining beams where then added.
132
I replace the supplied ply 4X4mm with my own 4X4mm wood for the pump well posts as I prefer the look. Planking the bulwarks is straight forward with some sanding of the edges to give a nice fit. I used small clamps to hold the planks in place as I find the ply ribs can split with the use of map pins
Deck gratings
With both the brass grating and the wooden grating i used mitre joints for the corners of the frames rather then butt joint, more fiddly but I prefer the look and no end grain to stain.
The next step is to attatch the gratings and plank the orlop deck.
Current Build:-
#68 Posted : 30 October 2016 16:19:16
Really nice and neat work Gil, this is going to look amazing when you're through with it Cool
#69 Posted : 30 October 2016 18:25:56
I`m really liking this one.
Drool Drool Drool Drool
Oh "NO" I feel temptation coming on.
LOL LOL LOL LOL
Keep up the good work. Cool
#70 Posted : 30 October 2016 18:33:09
BigGrin Nice work and looking brilliant Gil Cool
Shauncnh
#71 Posted : 30 October 2016 21:06:33
Great workCool, can't wait to see the rest of your build.
regards Shaun
Building-RC spitfire
#72 Posted : 30 October 2016 21:29:14
Enjoying your work Gil Cool she's really coming along now.
#73 Posted : 31 October 2016 00:27:42
Great job Gil. I am doing this as well. I'm up to 135 at the moment. It's a very time consuming little build isn't it but a joy to make. Look forward to seeing the progress you are making.
Chris. Cool
#74 Posted : 31 October 2016 00:39:04
Looking good Gil, coming along very nicely...Cool Cool
#75 Posted : 03 November 2016 13:40:42
Hi Gil.
Looking very nice. keep up the good work.
Ian Cool BigGrin
GilShapley
#76 Posted : 10 November 2016 13:18:48
Issue 132 Contd :-
Been on the back burner for a while whilst Grandparent duties took precedence
The gratings have been fitted and the orlop planking added, using the supplied 1.5 X 4 mm (not 1 X 4 mm as printed in the instructions). I followed the instructions here and have not stained the underside of the orlop, but will be staining the deck itself. Not sure whether to add the effect of nails in the deck planking and will have to decide soon as once the next deck is added there will be very tight access to the orlop.
Issue 133 involves fitting frame reinforcements, Cutting the lower gun deck ports and completing the orlop planking
More to follow
Current Build:-
#77 Posted : 10 November 2016 15:15:41
Really neat and precise work as always Gil
#78 Posted : 10 November 2016 15:50:14
Looking good Gil....Cool Cool
#79 Posted : 10 November 2016 17:09:18
Awesome work Gil. Doing a great job looks nice and clean.
Chris. Cool
#80 Posted : 10 November 2016 20:49:58
Coming along very nicely Gil Cool
Guest (6)
12 Pages «<23456>»
This page was generated in 2.122 seconds.
