HMS Hood Options
ALW
#1 Posted : 13 November 2016 17:34:20
Hi all
I've just received my Trumpeter HMS Hood 1/200 scale and cannot believe the size of this thing!
I've attached a photo of the box (up against a door to show perspective) the hull is the same length bar a few mm,and has nearly 1500 parts.
I've never made a ship this big and if anyone has any painting tips
I'd be grateful, thank you.
Regards.
ALW attached the following image(s):
#2 Posted : 13 November 2016 18:02:36
Hi Alan,
Looks great mate. I got Iowa and Missouri to make in same scale. Look forward to your updates on your build. As for painting I used a rattle can primer then airbrush for too colours. It takes a while to do. The hull bottom is best done in white ensign hull red. It's the nearest you'll get but it's enamel.
Chris.
ALW
#3 Posted : 13 November 2016 18:13:36
Thanks Chris
I ve just got to finish a motorbike then it's
The Hoods turn!
Definitely keep a diary and I won't be rushing
it as I sometimes do.
Cheers, Alan
Shauncnh
#4 Posted : 13 November 2016 18:15:50
That looks like one impressive kit,Cool can't wait to see this one take shape.
regards Shaun
Building-RC spitfire
ALW
#5 Posted : 13 November 2016 18:23:14
Hi Shaun
Its massive! I'm really looking forward to getting started on it.
I've been waiting a long time for the HK Models 1/32 Lancaster (taking ages to come out) and then the Hood appeared so I decided to go for it!
#6 Posted : 13 November 2016 18:36:38
It's certainly a beast of a kit Drool
When I get mine I will be using Lifecolor acrylics, they do two different WWII sets
https://airbrushes.com/p...o.php?products_id=22073
https://airbrushes.com/p...o.php?products_id=22072
I haven't decided yet if I'll use a rattle can primer or my usual Badger Stynylrez primer through the airbrush
#7 Posted : 13 November 2016 19:14:21
I will be watching this with interest.I used acrylics (Vallejo) on my Trumpy Arizona because it was too big for my spraybooth.Are you planning to correct the inaccuracies? There is a website that goes over all of the problems with the kit.Are you going to use and aftermarket sets?
#8 Posted : 13 November 2016 20:16:20
BigGrin Looks a great kit and you will have fun building herCool
ALW
#9 Posted : 13 November 2016 21:03:35
Can't wait to get started!
Probably wont upgrade or modify her but will just focus on doing a good job
with what I've got in front of me.
With regard to painting the decks, my plan was to paint them black then teak and gently rub so the plank joins show through. Are there any other ways of doing it?
Carl, Hi, I will be using Tamiya colours mainly using aerosol cans
and airbrush the colours that aren't available in aerosols.
Dave,Hi, thanks for the links. I've found the HMS Hood website. There is a lot of really useful info there.
Will post pics when construction starts.
Regards to all
#10 Posted : 13 November 2016 22:54:57
Hi Alan, looks an impressive kit. Can guarantee I'll be following your build every step of the way.... Good luck with the build.....Cool Cool
ALW
#11 Posted : 13 November 2016 23:53:29
Hi Alan
The box is so big took two of us to carry itLOL
Regards.
#12 Posted : 14 November 2016 10:08:58
Hi Alan, I will be watching your build with interest. The HMS Hood Association web site is a great source of info and as Carl said it goes into great detail over the Trumpeter kit.
ALW
#13 Posted : 14 November 2016 13:24:13
Hi Graeme
I will be checking the website-thank you. Whilst I'm not that confident at weathering etc, I will make every effort to make a good job of it, I'm particularly looking forward to painting the deck with a bit of detail.
This page was generated in 0.067 seconds.
