Paint Bleed Options
alemo
#1 Posted : 17 November 2016 17:24:30
Hi Everyone,
I am experiencing paint bleed under the roundel masks, they don't seem to stick very well to the colourcoats paint that I'm using. Has anyone any experience in this because one repaint is enough.
Alec
Adapt, improvise, overcome.
#2 Posted : 17 November 2016 18:05:58
BigGrin Apply a satin clear coat around the edges of the mask and leave to dry, then paint as normal the clear coat will seal the edges so you get a crisp line when the mask is removedCool
alemo
#3 Posted : 17 November 2016 20:35:00
Thanks Andy,
I'm air brushing the paint so I guess brush the varnish by hand?
Alec
Jimglghr
#4 Posted : 18 November 2016 19:41:02
Alec,
You should be able to spray the varnish on, but if you are having a current issue with paint bleed from the spray application, hand applying with a brush will give you more control and a better seal on the mask.
One caution - make sure that the varnish and the color you are using are compatible (test the paint stack up first on scrap) otherwise laying down the varnish first may lead to adhesion issues for the color and create a color void in this area and cause you more rework.
Hope this helps - Good luck,
Jim
alemo
#5 Posted : 19 November 2016 10:43:42
Hi Jim,
Thanks for looking in and the information. I will give it a try.
Alec
This page was generated in 1.391 seconds.
