Sound generator query Options
#1 Posted : 17 November 2016 20:21:46
Hope no one minds me asking but received my parts today with the much looked forward too sound generator.
Have tried the running sound and not sure what to expect but it does not sound as i was expecting.
I have looked on youtube and found these two videos (not my videos by the way)
The first video sounds like the unit i have received
https://youtu.be/vyTnX6w1Fjo
The second video has a sound more like i was expecting
https://youtu.be/2lxfLIS-QMk
Is there anyone please that could advise if possible the unit i have received is possible faulty ?
The whistle sound by the way is spot on so just not sure about the running sound i am getting.
I have used a fresh 9v battery to test as i do not have the 6 x D cells at tye moment should that make any difference.
Any advice would be appreciated.
#2 Posted : 17 November 2016 21:16:34
BigGrin Hi Tony
The generator as supplied to yourself will be the same one as supplied to everyone and we have had no other query's about the sound generated by it.
The second video sounds like he has added a different sound generator to the engine so thats why it sounds completely different.
#3 Posted : 17 November 2016 21:18:20
Ok many thanks for the update. That sets my mind at rest now.
Appreciate the quick reply.
dslinick
#4 Posted : 22 November 2016 21:44:56
Rank: Beginner Level 3
I suspect that hidden from view is a better set of speakers. The small speakers furnished with the kit have to fit underneath the stand and they can't reproduce any of the low frequencies that a true "chug chug" sound requires. I am considering a set of computer speakers, with built in amp and subwoofer. I bet that would make a huge difference.
#5 Posted : 22 November 2016 23:39:23
The sound for that loco is actually wrong for the speed of our loco. Its speed is constant as should be the sound which is how ours is, that loco also has many mod's, starting with the huge box item aft of the chimney.
#6 Posted : 04 December 2016 19:45:54
Many thanks everyone for the advice on this one.
I had queried it because sadly my sound box was damaged in the post so i was unsure if it had damaged the unit as well as having a crack in the case.
Phoned cs and they had a replacement to me in less that a week so all is now well.
This page was generated in 0.111 seconds.
