33 Pages «<910111213>»
Deagostini 1/144 Thunderbird 2 Build (stevegbr) Options
stevegbr
#201 Posted : 17 November 2016 20:48:42
thanks all, every home should have one of these.
stevegbr
#202 Posted : 17 November 2016 21:15:30
parts from part 37.
stevegbr attached the following image(s):
stevegbr
#203 Posted : 17 November 2016 22:21:19
here are the parts for this build.
stevegbr
#204 Posted : 17 November 2016 22:24:07
this is the front part of the elevator car.
stevegbr
#205 Posted : 17 November 2016 22:26:13
front and the rear part assembled.
stevegbr
#206 Posted : 17 November 2016 22:28:13
these parts are gear strips for the telescopic legs.
stevegbr
#207 Posted : 18 November 2016 16:25:46
here is part 38, and parts.
stevegbr
#208 Posted : 18 November 2016 16:27:06
the canopy of the elevator car.
stevegbr
#209 Posted : 18 November 2016 16:28:09
elevator car three is now complete.
stevegbr
#210 Posted : 18 November 2016 16:29:09
here is part 39, and parts.
stevegbr
#211 Posted : 18 November 2016 16:30:43
the wheels and shafts are put together.
stevegbr
#212 Posted : 18 November 2016 16:31:56
here is part 40,
stevegbr
#213 Posted : 18 November 2016 16:33:17
this vehicle so far.
stevegbr
#214 Posted : 18 November 2016 16:34:25
the two gears are put in place from the previous part.
stevegbr
#215 Posted : 18 November 2016 16:35:56
the two small gears and shafts at the front are in place.
stevegbr
#216 Posted : 18 November 2016 16:36:58
and one gear and shaft at the rear.
#217 Posted : 18 November 2016 16:49:08
It's looking great - but what are the four long steel shafts protruding from the brass leg pieces?
Roy.
stevegbr
#218 Posted : 18 November 2016 16:53:34
hi roy, the are like coil spring, which connect to the two white gear strips, when the motor is switched on they push the telescopic legs out and back in again.
#219 Posted : 18 November 2016 17:38:51
Aha.... Clever stuff!
stevegbr
#220 Posted : 18 November 2016 18:09:07
here is part 41 and parts.
This page was generated in 0.372 seconds.
