Where to put the Spitfire Options
max001
#1 Posted : 30 November 2016 03:45:15
Hi Trev, A while ago I built Hachette Lancaster 1/32 scale,built a corner table was going to put another shelf on but although the Spits wing span is slightly shorter the fuselage is longer,so new 2 story corner shelf 2 ply sides painted sky blue with a faint smidgen of cloud 2 shelves covered in fake grass 2 acrilix doors and 2 sets of wheel chocks. Thank you Trev and the other guys for your remarks it gives you a gee up feeling, I have been in touch with Bisett magazines and they have told me I may not get my issue 31 till January is there any problem with issue 31? Max.
greyhawk
#2 Posted : 30 November 2016 10:06:24
Do you have the dimension of the Lancaster handy? I may be able to get my hands on a Lancaster kit, but I need to know the size of the model to be able to determine if I need a new apartment first to store it. Or a warehouse. Actually I should just open a partworks museum.
max001
#3 Posted : 30 November 2016 13:20:17
wing span381/2" 98cm fuselage 271/4" 69cm tail wing span 113/4" 30cm height 61/2" 16cm. max
#4 Posted : 30 November 2016 18:35:51
The Hachette Lanc is a baptism of fire in terms of kit building and rare as hen's teeth as a completed build or kit. Personally I would wait for the HKM 1/32 Lanc
This page was generated in 0.141 seconds.
