help needed on fairing the ribs Options
darrend
#1 Posted : 17 January 2011 19:36:28
hi all,
as you can see i seem to have a problem with the fit of part 7 well the run from rib 16 to rib 13 and onto part 7. do i need to fair more off the ribs or should i be building out part 7?
thanks all
darren
darrend attached the following image(s):
#2 Posted : 17 January 2011 20:28:18
from what I can see is,a small amount of fairing on the two front ribs,then you have a bend in your planking, to gently bend round to the front.hope you understand this.
darrend
#3 Posted : 17 January 2011 22:53:42
thanks Karl. will give that a go see if it helps
#4 Posted : 18 January 2011 10:16:00
The planking at that point is meant to follow the line of the frames, therefore as Karl says, a small amount of fairing on the two front frames, and then slightly bend the planking to suit.
darrend
#5 Posted : 18 January 2011 19:15:56
thanks tomick. i will see if i can get this right now
This page was generated in 0.032 seconds.
